Old 04-04-2010, 05:19 PM   #16
Integra's Avatar
Originally Posted by newuserlosi8t View Post
what do u mean i got them with the truck what offset should i run it is a 1.0 not the 2.0
1.0 needs 1/2" offset of the 1/2" extender's and zero offset.
Old 04-04-2010, 07:19 PM   #17
pyromania's Avatar
Trader Rating: 18 (100%+)
My comment was directed toward inferno. You're cool.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 04-04-2010, 07:47 PM   #18
Suspended
Trader Rating: 202 (96%+)
how did u do double mounts? i have one single mount
used the two holes dead center of the shock tower above the diff
and cut down a 1.0 body mount did u drill holes in ur tower and use 2.0 mounts? or is that a 2.0 shock tower?
and what brand wing is that does it work good looks agressive
the front mount lined up perfect so i did nothing with front, the rears i did drill 1 small hole on each side of the mount and just moved the body mounts down. really not sure what wing it is, i havent run it yet with that body or wing.
inferno13 is offline   Reply With Quote
Old 04-04-2010, 07:52 PM   #19
Suspended
Originally Posted by pyromania View Post
You know you're using the wrong offset wheels.
dint know there was a right or wrong, i use what works for me, and according to the differnt tracks i run, ran 2 weeks ago at nitro rising race a took third, so i dont feel i did to bad, or with 0 offsets, do you think i would have took 1st or 2nd....lol, also 1st-2nd-3rd place where all losi 1.0.....lmao
Old 04-04-2010, 07:54 PM   #20
pyromania's Avatar
The 1.0 uses 1/2" offset rims. Don't the wheels rub on the body when turning?
Jesse Carrillo
Team Driver For:
Old 04-04-2010, 07:59 PM   #21
Integra's Avatar
the front's actually don't line up perfectly.(on the body at least) the holes on the tower are a mm or 2 off from the 2.0's therefor the pre cut body holes in the stock 2.0T body are slightly off using the 1.0 holes with 2.0 mounts.
Old 04-04-2010, 08:00 PM   #22
Suspended
no rubbin at all.
Old 04-04-2010, 08:03 PM   #23
Integra's Avatar
proper offset will do wonder's for the handling of the vehicle......denying yourself of that is a real shame and your attitude doesn't help either....were only trying to help here.
you need 1/2" offset rims OR 1/2" extender's then you can run zero off but with the stock hexes you are supposed to run 1/2" offset.
Old 04-04-2010, 08:03 PM   #24
Suspended
i dint have to do anything with the front, i am useing the 1.0 mounts, front was right on. dont know if this will show much, but here it is
what do u think losi 8 t 1.0 with 2.0 body-losi1.01-001.jpg   what do u think losi 8 t 1.0 with 2.0 body-losi1.01-002.jpg   what do u think losi 8 t 1.0 with 2.0 body-losi1.01-003.jpg
Old 04-04-2010, 08:12 PM   #25
pyromania's Avatar
Big +1
Jesse Carrillo
Team Driver For:
Old 04-04-2010, 08:14 PM   #26
pyromania's Avatar
I think the JC body doesn't come with pre-drilled holes.
Jesse Carrillo
Team Driver For:
Old 04-04-2010, 08:20 PM   #27
Suspended
dint mean to show attitude, sorry, i will forsure give it a try, i have only raced it one time at the rising nitro race and it did well, what exactly will the 1/2 offset help???? i dint have any problems with it flipping or anything, but did notice a little rear end sliding in corners
Old 04-04-2010, 08:22 PM   #28
Integra's Avatar
this is true...looking back i see he has a JC punisher....so moot point on that subject. the offset is a different story.
Old 04-04-2010, 08:28 PM   #29
pyromania's Avatar
I was looking at his avatar and noticed it was the JC body. If it wasn't for that quick glance I wouldn't have even noticed.
Jesse Carrillo
Team Driver For:
Old 04-04-2010, 08:36 PM   #30
Suspended
ok, since i learned about the offset wheels here tonite, can anybody help with why the rear slides around in corners, and what sway bar they use for a big loose track? pretty much just better high speed traction in corners, i am running soft i-beams for tires.
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
1/10 EP buggy racing johnboy1 Singapore R/C Racers 22 08-31-2009 11:50 PM
what do u think of the b44 playboy Electric Off-Road 94 12-23-2007 11:28 PM
