Old 04-03-2010, 10:41 AM   #1
Default Seized Carb......
This is the second time its happened. The carb barrel is seized and it wont side on the body, like its been welded shut.
I ripped the carb apart the first time and it seems like the barrel is caught on something at the mouth of the body, almost like the barrel is slight too large in diameter, I have to really force it in. I eventually got it to slide smoothly after polishing the carb body with a scotch pad dremel bit.
But it happened again this morning after a front end collision with a rock at low speed ( just like last time), the carb completely locked up, I am about to rip it apart again.
Any ideas? Its a LRP 28, Ill get some pictures.
funkhouser is offline   Reply With Quote
Old 04-03-2010, 10:52 AM   #2
PS: idle screw was loosen, taken out.
Old 04-03-2010, 11:13 AM   #3
Found the problem, there was a hairline crack on the body, it shattered when I tried to pull the barrel out.
New carb or can I still run like this?
Got a few old carbs laying around,
axial 28 and a AE 21 from a MGT.
any chance I can run them on the lrp?
w ww.aww-kittah-aww.com/up/files/1680/IMG_5326.jpg
take out the space after the first W as I cant post pics yet.
Old 04-03-2010, 11:15 AM   #4
fatdaddy's Avatar
heres your pic. i wouldnt run it anymore. just find the carb that has the same diameter neck as the old one and toss it in.
remember you will have to re tune the motor after this though.
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 04-03-2010, 11:20 AM   #5
Thank you, another issue is I cant even pull the carb from the crankcase, its in there pretty good.
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
Seized/Frozen RC engine! Cheezburger Nitro Off-Road 9 10-25-2008 09:34 AM
Any tricks to removing a siezed carb?.. fastharry™ Nitro On-Road 19 09-06-2003 10:13 AM
