OFNA Picco?
OFNA Picco?
Alright people, anyone that has seen driven or owns an ofna picco i need you to tell me what they are all about because im looking to buy one. like how does it handle? is it quick? is it good 100% stock out of the box (besides tires) how does it jump? is it an over all good buggy? is it a good racer? Please tell me all you know, because i dont want to buy something thats not worth it.
its definitely worth it, I've had a few and never been disappointed with power.
re
if you are talking about the buggy yes it is good out of the box except the tires and the steering servo neds to be upgraded
Excellent beginner buggy, the engine is a screamer once you bolt on a 086 pipe with a long header. I loved mine. I ripped all the electronics out of it as soon as I opened the box. I've been using 2.4ghz radios and digital servos for as long as I can remember, no going back to analog or crystals for me. It's a bit heavy but that can help newer racers. All in all, it's a great little club buggy. Suspension is ultra smooth, the stock oil is a tad light for my taste.
The tires were good for one or two races, surprised me because I thought they were too hard period. Did not expect them to work at all on a hard pack surface.
The only things I broke were one or two arms. I stripped the pillow ball threads out. It took a ton of abuse before it happened but that's to be expected when you repeatedly slam into a wooden wall! I suck with a buggy.
I also twisted one rear dogbone in two. That's all the problems I had with it.
You'll want a starter box for sure. The engine is a bear to turn over for the first 1/2 gallon, even with preheating. It broke in fully by 3/4's a gallon and by 2 gallons it was running with all the high dollar mills. It flat out will kill a Nova 3 port and any other RTR engine out there. The 086 pipe really made a big difference.
I ran O'Donnell's purple sport plugs, medium cool range long plugs and Byron's 30% Pro driver fuel. It made good power from bottom to top with temps around 230-245F. Easy 40mph.
It's a really nice mill. Put a new set of bearings in it around 2-3 gallons. I ran mine just to see how long it would go with no maintenance. At the start of the 4th gallon the bearings went. If I had replaced them I'd still be running the engine.
The diff fluids are too light in it as well. They put 1k in the rear, WAY too light. I think 7k int he front and center diff with 3k in the rear would be a good starting point.
