Old 04-02-2010, 11:31 PM   #1
Default Carb Loose on Go .21
Hi
I've just bought a new second hand Go .21 for my 8ight 1.0. To fit it I had to loosen the set screw and rotate the carb slightly. Now when I tighten the screw as much as I can, the carb can still rotate. Is this normal/a problem?
Ben
teamshaw is offline   Reply With Quote
Old 04-02-2010, 11:38 PM   #2
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Originally Posted by teamshaw View Post
Hi
Ben
Well, no it shouldnt be normal. Yes it can be a problem. Make sure the screw is tight enough and that its arranged properly. If you still have the problem it can get worse when it heats and the metal expands. To solve it you can put at the right angle, then seal it with a sealant. Now im not 100% sure on what sealant to use but if you find a high temperature sensor safe sealant for automotive use it should work fine. Also check if the O-Ring is warped or dried and rotted away, if so replace it that could be the entire problem.
EDIT: Just looked at a thread a few topics down and heres a good sealant.
http://www.lucky7rc.com/product_info...roducts_id=247
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 04-02-2010, 11:59 PM   #3
shanty140's Avatar
Nope it is not normal. Check the pinch bolt setup, o-rings, etc and make sure everything is ok. For sealing the carb I recommend the lucky 7 sealant as well. It is what I use on my motors and works awesome. When you apply the sealant DON'T put it into the internal parts of the motor, like the carb neck, and inside of back plate. It is a wicking type sealant and when you apply it, you should put it on the outside of whatever your sealing and it will find it's way to where you are wanting to seal. For example, when the carb is tightened down, put the sealant around the outside of the base of the carb and case.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 04-03-2010, 12:02 AM   #4
Trader Rating: 21 (100%+)
I had the same problem. Turned out that the ring around the carb neck (part that goes inside the crank case) was moving freely over the carb neck. I tried lucky 7, super gluing it ... nothing worked ended up replacing the carb with a grp carb that fit perfectly and the motor ran better than ever.
TopGearRC is offline   Reply With Quote
Old 04-03-2010, 03:14 PM   #5
Thanks for the tips guys. I've ordered some of the Lucky 7 sealant, hopefully it makes it over here to Australia before next weekend's race meeting.
I'll try and get the carb off and check out the o-ring in the meantime. I had a quick try and it was pretty hard to get off but I've read that it can be difficult so I shall keep trying.
Old 04-04-2010, 02:17 PM   #6
Flanno's Avatar
If your in OZ, why don't you contact Mark @ MASSIVEMODS ?
A new Gen Carb would be cheaper here, than to buy and ship some sealant from the USA !
As I think you'v done as XJ above done to his when you rotated it.
I use; MG66.21, .21 Godzilla R7, GO .21 gen5.5 5port, GO/MM3 .21 gen5 5port, +Go2072, 25% NEO+, KO Propo Helios, Mugen MBX6T + MBX6, AKA Tires, Pyrographix, BCE X5mm.
Sponsors; Factory MG66/GODZILLA (MassiveMark NAA) +MMI (mugen/NEO+)+PerformanceRC +TQgrafix +AKA. I also support; LRRCC track sponsors when I can.
Flanno is offline   Reply With Quote
Old 04-04-2010, 03:03 PM   #7
Peter Martin's Avatar
I have seen this a few times. Check the opening in the case where the 2 pieces to clamp the carb are. The ones I have seen that do not tighten down...the opening was not machined large enough to make the clamp bite down.
Peter Martin is offline   Reply With Quote
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9300 03-27-2017 05:54 PM
Official Go Engines Thread MassiveMods Australian Racing 1862 02-13-2012 04:44 AM
