Old 04-02-2010, 09:15 AM   #1
mudboger07's Avatar
Default Shimming diffs
Im in the process of rebuilding the front and rear diffs on my losi 2.0 buggy, my question is does the center diff need to be shimmed also? Or just rebuild it.
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 04-02-2010, 10:55 AM   #2
JLuke2's Avatar
Nah no need to shim the center, the only reason you shim the front and rear is to set your gear mesh, whereas on the center you're setting your gear mesh with the motor, and also, if your center diff slops around front to back alot, you shouldnt need to shim it, something else is wrong.
JLuke2 is offline   Reply With Quote
Old 04-02-2010, 11:02 AM   #3
mudboger07's Avatar
cool thanks for the info, i didnt think it needed to be shimmed but i wanted ot make sure before i put it back together....
Ken
Old 04-02-2010, 11:38 AM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
Are you talking about the shims that go on the outside by the inserts in the gear case or are you talkkng about the shims on the inside of the diff that go under the sun gear.
Old 04-02-2010, 03:43 PM   #5
mudboger07's Avatar
The ones at the diff case, I have the ones under the sun gear shimmed correctly i hope....lol
Ken
Shimming diffs question... portyansky Nitro Off-Road 16 03-26-2011 06:02 PM
Mini LST2 Diffs skent Micro and Mini Scales 16 02-23-2009 12:33 PM
I dont get "shimming" please explain... assivaen Nitro Off-Road 29 01-21-2009 09:45 PM
need help... mini inferno smoking mip diffs. gweed Micro and Mini Scales 19 09-11-2008 09:46 AM
