Old 04-01-2010, 10:25 PM   #1
Nitro F150's Avatar
Default How can I get my truck ready by saturday?
Ok my local track is having the first races on saturday, Im still a rookie at tuning. I got a new engine about 5 months ago never broken in to. Im off of school tomorrow is it possibel for me to get my truck ready by saturday?
Nitro F150 is offline   Reply With Quote
Old 04-01-2010, 10:55 PM   #2
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
That's a hard question for us to answer for you. I certainly wouldn't suggest rushing anything, especially if you're new to nitro tuning. Do a proper break-in on your engine, or you could shorten it's lifespan considerably.
Go through your RC car/truck and check and make sure all the screws are tight, and that no moving parts are binding. Find out what parts are prone to breaking and get spares. Make sure your clutch is in perfect condition.
Just take your time and try to do it right or you could end up frustrated.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 04-01-2010, 11:22 PM   #3
Bigedmond's Avatar
Trader Rating: 18 (100%+)
There is a way, and I don't personally recommend it.
This break in method was mentioned in a Magazine a couple years ago, and i have seen it used by MANY pros at races like Nitro Challenge and Silver State.
Have everything ready. Brand new fuel, starter box, heat gun, a Charged ignitor, temp gun, radio and tuning screw driver.
1. Turn on the radio system, and fill the tank and prime the motor. I recommend priming the engine by blowing into the pressure line. To do so, remove the fuel line from your exhaust and blow into the line until you see fuel enter the motor. Reattach the fuel line.
2. Heat the motor to roughly 160 degrees. You can go higher. Now start your motor and keep it idling. Lean the top end 3 hours so the motor will heat up, and you want it to idle between 160 and 200 degrees for 2 minutes.
3. At this point, you have to pull the trigger on your radio to almost full throttle. While pulling the trigger, you HAVE to, HAVE to richen the motor roughly 2 full turns. The motor should barely run, and should have alot of fuel blowing out of the exhaust.
4. Hold the trigger until you see the tank is almost empty. Once you get to this point, let off of the throttle and lean the motor back out. Refuel the tank and let it idle again at roughly 170 to 200 degrees.
You have to repeat steps 3 and 4 roughly 4 times; each time ramping up the temp so you idle temp should be 200 to 220 degrees.. At this point, you can start running the motor on the ground for a couple tanks and putting more of a race tune on the motor.
Again, i don't recommend this method. Stick with the method in the Break in Bible if you can. This method works, but i believe it shortens the life of the motor. Good luck, and have fun racing.
Bigedmond is offline   Reply With Quote
Old 04-02-2010, 12:00 AM   #4
merdith6's Avatar
Default Honestly....
It takes a long time to break an engine in....If you can use the old engine this weekend and if you just have to then you will need to stay up late....But like the above said, take your time and be patient, and check your car over really good.....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 04-02-2010, 06:52 AM   #5
noR
noR's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to noR Send a message via MSN to noR Send a message via Yahoo to noR
Sure, you could put 1G through in a day maybe. Have a couple spare glow plugs and get started.
Follow the normal break-in method.
That WOT method posted above sounds crazy.
Check out my local track --> http://trackseeker.lefora.com/2009/05/01/trackseekers-18-scale-offroad-track-04302009/page1
noR is offline   Reply With Quote
Old 04-02-2010, 07:01 AM   #6
madweazl's Avatar
I had to do a quick break in a couple weeks ago. Idled one tank through it at 200-240ish and then ran 3 tanks through it doing small runs varying throttle input as much as possible. Threw it on the track for 2 rich practice sessions and then raced it. Tune still changed a bit each qualifier and engine temps dropped each run as well.
Raced it again the following weekend. It now has 1/2 gallon on it and has had a "race tune" for most of that. Couldnt tell you how long it will last but it runs great.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 04-02-2010, 08:27 AM   #7
Yes, its possible, you can break in your engine today, you will end up going to about midnight tho. just remember you rush the engine, the life span is short. I run vspecs when I break in, I heat the engine up make sure its wrapped in foil, Idle 2 tanks, before cool down. after that I run 3 tanks at the track, nice and easy. my vspecs last about 6 gallons - 8-9 with a pinch. I know that RBs and novas take way more time to break in... But it can be done
I'm not sponsored so it does not matter what I put here.
Shuming is offline   Reply With Quote
Old 04-02-2010, 08:34 AM   #8
my new motor is still not fully broken in and it's seen about a gallon of fuel. And it has been more then 3 weeks.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
Palm Beach County south county park edm rob Florida Racing 2392 01-02-2012 06:38 PM
Greater Los Angeles Club Meeting this Saturday 2.20/10 Danny A. Nitro On-Road 95 03-23-2010 01:01 PM
