Old 04-02-2010, 12:55 AM   #16
neobart's Avatar
I wouldn't recomend cityblocks for that track surface. They're only good for bluegroove in my experience. Tried them on a similar surface and I had zero grip. But that might have been because I was using the medium soft compound. M3 calibers was the tire of choice for that track, so that's my recommendation, that or i-beams.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 04-02-2010, 05:11 AM   #17
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
m2 or m3 Calibers
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 04-02-2010, 05:49 AM   #18
Stubbs's Avatar
Trader Rating: 57 (100%+)
Originally Posted by tc5 man View Post
makes sense have you ever notice, though that on a smooth grippy track the city blocks grip to much? and not be able to have any give in the rear ? i do think though thats, just the setup i was using though.
Absolutely, there will be certain conditions where the Cityblocks will prevent the rear of the truggy from rotating easily. In those conditions, the City-Beam will sometimes free up the rear end a tad.
Shane was right though, before you start chasing tires, get a good base set up on your truggy. Also, don't go making broad sweeping changes all at the same time. That will be too many variables to contend with. Start with a base set up, and make small changes, one thing at a time, and see what the results are.
I've seen folks change 4 or 5 settings at one time, AND switch tires. There's no way to tell what efffect each change had, because you don't know which one made the difference.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 04-02-2010, 06:37 AM   #19
Soft AKAI beams, just looks a little to loose for city blocks
I'm not sponsored so it does not matter what I put here.
Shuming is offline   Reply With Quote
Old 04-02-2010, 07:19 AM   #20
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
This is VERY good advice. Make ONE change, note the effect, and continue from there. And the stock Losi tires are not "bad" tires... although there are probably better choices for your conditions, they aren't the worst.
I personally like cityblocks in the conditions described, and calibers are very similar. Others may not like them.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 04-02-2010, 09:33 AM   #21
tc5 man's Avatar
when i did the city block on the front, and i-beam in the rear it helped a lot feeing up the rear end. on my buggy that is
my experience with running city, blocks all around and not freeing the rear end up is when track, gets real tacky and smooth.
Old 04-02-2010, 09:36 AM   #22
Soft I-Beams, Soft Cityblocks, M3 Calibers, etc.
If you don't need a mini pin, you can probably get away with Cityblocks or Calibers anywhere. They may not be the BEST, but they will work anywhere.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 04-02-2010, 12:16 PM   #23
madweazl's Avatar
68 degrees ambient air temp to start the day (to a high of 76). Super soft Crossbraces on the yellow wheel and soft I-beams on the white wheel.
Track was extremely wet in the morning; the Crossbraces were awesome. No damage occurred the first run. During the second run the track dried considerably (even during the run); a few lugs on each tire were starting to tear.
First qualifier was extremely wet; Crossbraces left on. No further damage observed.
Second qualifier pretty dried out; CityBeam configuration used (both soft). Great grip.
Main, track watered during the first heat and then again right before the buggy main. Crossbraces all the way around (temp now showing 76) as they were the only tire in my box that would clear the mud from the lugs. Soft would have been a much better choice but I didnt have any on hand. Resulting damage is what you see in the pics.
Supersoft
Soft
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 04-05-2010, 07:57 AM   #24
So sounds like soft i beams are my best bet. I don't want to glue them so i was gonna buy them already mounted. Hope they come close to balanced. We'll see.
bacchus is offline   Reply With Quote
Old 04-05-2010, 08:44 AM   #25
Frank L's Avatar
Trader Rating: 148 (100%+)
I always balance them. Some take a little and some take a lot but still always balance them. It's one less thing for the suspension to fight.
Old 04-05-2010, 08:47 AM   #26
deweyharding's Avatar
Trader Rating: 39 (100%+)
VP-Pro utralflex Axmen with wide tire on narrow rim on the rear.
deweyharding is offline   Reply With Quote
Old 04-05-2010, 10:09 AM   #27
mblgjr's Avatar
Trader Rating: 86 (100%+)
PL M2 Calibers would be a good baseline if there is enough surface "fluff" to dig into.
JC Blue Crow-bows would also work well.
Losi Red XBT/Eclipse combo. Greens have potential, but are shearing lugs on rough/high traction tracks.
JC blue Subcultures, AKA Soft City blocks, PL Revolvers all could work if it grooves up and the groove goes 80%+ clean dust-wise.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 04-05-2010, 02:07 PM   #28
+1 on the xbt front/ eclipse rear combo.
bacchus: You should learn how to glue tires. It's really easy.
TPJ International
071crazy is offline   Reply With Quote
Old 04-05-2010, 02:54 PM   #29
I can glue tires just don't wanna anymore.
Old 04-06-2010, 03:51 PM   #30
Trader Rating: 45 (100%+)
Race groove is hard packed and alittle rough. No blue groove. Outter edges of race groove is loose and dusty. I'm a new racer so i'm in the loose a good bit lol. I'm thinking proline calibers soft? I need traction help! Running the stock medium losi tire now.
Try bowfighters ...m3 bowtie rear ... m3 crimefighter front you'll love it
rc racer 103 is offline   Reply With Quote
BCE speed Losi 8ight "T" 2.0 3mm chassis xxxtcr Nitro Off-Road 246 08-02-2013 08:44 PM
Losi 8ight T 2.0, Futaba 3PKS, Hyperion, AKA, Novarossi, Hudy, AMB, tools looneytune R/C Items: For Sale/Trade 27 01-04-2010 04:35 PM
8ight-T 2.0, Motors, and Tires for sale. NeoNot R/C Items: For Sale/Trade 25 05-17-2009 06:54 PM
Losi 8ight Truggy 1.0 + a TON of extras. CHECK IT OUT ! RShafer R/C Items: For Sale/Trade 30 04-25-2009 07:55 PM
