Old 04-01-2010, 05:01 PM   #1
Default What do you use to flame tires???
What kind of cleaner/ Stuff do you guys use to flame your tires before a race. I need the tire to Be very soft for night racing. Yes i know they dont last long once you do it to them tires are not a problem just traction when it gets late and Cold. Thanks for any help
Speedyrob is offline   Reply With Quote
Old 04-01-2010, 05:22 PM   #2
do you mean heat up your tires? because you can get soft and super soft compounds for cold weather traction. if you are lighting your tires on fire, as flaming suggests, im not sure i can help you.
C.Harper is offline   Reply With Quote
Old 04-01-2010, 05:25 PM   #3
chuckinator's Avatar
I generally use motor spray and a lighter. Be carefull when you do it though. If you do it for too long it can change the compound slightly and have the reverse effect that you are looking for.
Chuck Hicks
TLR, Novak, Proline, Spektrum, Horizon Hobby, shortcoursehobbies.com, SPY optic, Competition Hobbies
chuckinator is offline   Reply With Quote
Old 04-01-2010, 05:30 PM   #4
Slider30250's Avatar
WD-40 works, it's flammable. But before you flame your tires with it try just spraying a light coating on the tires after you have cleaned them and put them away in a large zip lock bag to sit over night. The WD will soften them right up and it's not as destructive as flaming. Also for more traction you could try going less stiff on the front and rear sways, that will help also.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 04-01-2010, 05:30 PM   #5
Yes im wanting to heat it up and soften the tire more im already usong SS and i know flaming the tire well soften it up. I have tryed tire softener but dont work to well. Im race in the night when the ground gets Cold. Motor spay huh ill try it about how long i hear about 20 sec a tire. Speedy
Old 04-01-2010, 05:32 PM   #6
Thanks for the tips. Speedyrob
Old 04-01-2010, 05:33 PM   #7
Speedy what exactly is the track conditions, hard packed blue groove, packed with a dust layer, loose and loamy? And what tire are you using for the surface?
Old 04-01-2010, 05:37 PM   #8
Cold,Moist, hard packed. Im running a panther raptor Super Soft. I see everyone esle running small pin so im not far off. Losi 2.0 buggy stock setup. I even set my epa so im not pullin no more than half throttle and still not the traction everyone esle is geting. Speedyrob
Old 04-01-2010, 05:44 PM   #9
Try a J Concepts subculture in blue (soft) compound or a Pro-Line Caliber in M3 (soft) compound. After looking at the Panther tire I think I know what's happening, with the super short pins on that tire I would say you're tread is loading up with track dirt and causing you to lose traction until you get the tires spinning fast enough to clear the tread out.
Old 04-01-2010, 05:50 PM   #10
Eric Thompson 2's Avatar
On several company's super soft compounds, traction additives do not sink in causing the tire to just be slimey.
Serpent America
Eric Thompson 2 is offline   Reply With Quote
Old 04-01-2010, 05:51 PM   #11
So too small of a pin ill buy some calibers in soft and try that. Speedyrob
Old 04-01-2010, 05:59 PM   #12
They should serve you well and the two step pin design is a lot more resistant to loading up with dirt than a tire with a really small short pin. Those Panthers I would use on dry hard pack. Either clean or with a little dust layer. Also when you go to mount the Calibers, they are directional. How you mount them will decide how the do in certain conditions. Follow the link and read the tire features.
http://www.prolineracing.com/product...es-253-75.html
Old 04-01-2010, 06:04 PM   #13
madweazl's Avatar
Not soft enough? I had a set of AKA super softs and they literally stuck to my table!
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 04-01-2010, 10:06 PM   #14
If the compound is too soft the pin will just fold over on the track and not acutally dig and thus have no traction. Just one thought.
Also you said that you are running a Losi right? How old is the car. If it is brand new out of the box with less then say 1/2 gallon of fuel on it, it will not create traction do to the car not being broke in.
Chuck Hicks
Old 04-01-2010, 10:13 PM   #15
imaxx21's Avatar
Send a message via AIM to imaxx21
Proline's M3 and AKA's Super Soft are much softer than Panther's
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Team Losi XXX-T CR, What are yours opinions ? Jason Pelletier Electric Off-Road 2231 01-19-2012 09:16 PM
Tire Softners?? what have you used jabroni racing Nitro Off-Road 14 02-26-2010 09:26 PM
New Jaco Rubber Tires yyhayyim Electric On-Road 601 07-07-2009 04:13 PM
How do you keep the dirt off? Jaz240 Nitro Off-Road 46 05-01-2009 04:15 PM
