Old 04-01-2010, 01:22 PM   #1
8IGHTROCKETX3's Avatar
Trader Rating: 59 (100%+)
Default what parts for the RC8?
just got a RC8 roller, and i want to make a list of frequently broken parts for the 8 so i can stock up.
so what, if anything are you guys breaking?
8IGHTROCKETX3 is offline   Reply With Quote
Old 04-01-2010, 03:17 PM   #2
awidz's Avatar
Thumbs up not much
i have ran my rc8b all winter racing indoors, and have yet to replace anything but the clutch bearing. the car is really solid, you will not go through much of replacement parts.
awidz is offline   Reply With Quote
Old 04-01-2010, 03:42 PM   #3
I would say make sure it has the alumnium top plate. other than that it comes down to driving, im not that good yet and still crash alot so i break all the time.
rc8 racer is offline   Reply With Quote
Old 04-01-2010, 07:35 PM   #4
Goomba_7's Avatar
The RC8B is a real solid buggy. Once I became pretty decent at throwing it around a track I really haven't broke anything. I did break a couple of turnbuckle ends, and wing mounts from serious lid slams, but if you keep the thing on 4 wheels you'll be replacing things for maintenance rather then cuz things broke. But I agree with RC8 Racer if your roller doesn't have the Aluminum top plate in the front or the Team A, B, C, and D blocks then those are definitely good parts to upgrade to right away to get more durability out of the first buggy. If you Check out the main RC8 thread and roam through it you could probably find everything you would want to know.
Serpent Cobra S811, Which ever engine is running good for me, VP Fuel, Savox Servos
"A bad race day is still better than a Good work day!"
Goomba_7 is offline   Reply With Quote
Old 04-01-2010, 11:43 PM   #5
Ok well here is my list of stuff I drag to races. Mind you most of these things have not broken but here goes...
Bearings (8x16x5 and 15x21x4) at least a couple of each, if one siezes you have a replacement
Hinge Pin Bushings (The one, two, three dot things, these wear, can help tighten up that suspension)
Hinge Pins (Outer and Inner)
Top Shock Bushings
Those little red and blue bushings
Shock Shafts (These have and do bend on good hits (remember not always your fault, sometimes that crazy knuckle head who hits you head on))
A-Arms (Front bottom and Tops, Rears)
Rear Hub carrier (used to break these on my T alot, none on buggy yet)
Clutch (Always have a spare complete clutch, bell and flywheel)
Camber Links (Any ball links really, they tend to be one of the first things to break in a hard impact (Not a bad thing )
Spare screws/ nuts (All sizes, but most important, 3x12s, 3x14s, 4x12s, 4x14s, M3 locknuts, M3 Flanged for shocks, also the top shock screws and the motor mount ones with lock washers)
Diff Cases
Exhaust hanger ( also the set screws for it)
Spare Glow plugs
Spare Fuel Tubing
Spare Fuel Tank
Complete Air Filter Assembly (Also spare filter elements)
Wheel Nuts
Optional:
Dog Bones (F/R and Center) / Rebuild Kit (they get bent and worn)
Outdrives (F/R)
Turnbuckles
Anypart that you upgraded with something else
Servo (Something that can do double duty if needed)
Battery for reciever
I'm sure there are other things to add to this list. This is the minimum I would go with to a race. I have almost always had a part I have needed if something broke on my car, and in most cases even for other's RC8/ RC8T... I also in worst case, always can strip stuff on my RC8T chassis. Also most of the spares I have are parts that have been upgraded or when I buy parts, I buy them in 2's.
Tekno NB48 Samurai Proline Tires
Tekno NT48 XZB Speed Proline Tires
Tekno EB48.3 Viper Proline Tires
Tekno / Dialed RC Hobbies / TKO Competition Development /
Stirex is offline   Reply With Quote
Old 04-02-2010, 12:22 AM   #6
MontanaMaxx's Avatar
my buddy broke front knudckles but tahts all id add to the list
whats that law that its always the piece you dont have that breaks? just get a spare car and you will be set
MontanaMaxx is offline   Reply With Quote
Old 04-02-2010, 08:36 AM   #7
just go buy another glass machine and use one for broken parts
I'm not sponsored so it does not matter what I put here.
Shuming is offline   Reply With Quote
Old 04-02-2010, 08:59 AM   #8
NJA82's Avatar
Trader Rating: 33 (100%+)
Send a message via MSN to NJA82
^^ is that supposed to mean the RC8B is fragile, come on man, its one of the strongest buggies on the market, i race with guys that are breaking other cars more often than i see an Associated sidelined...
Only part i replace often is bearings, depending on the track conditions they can last very little time, that and clutch bearings/shoes but thats just wear and tear and car will do the same, otherwise my RC8B and RC8T are stock minus the alloy rear hubs and i have broken ZERO parts on either of them.
NJA82 is offline   Reply With Quote
Old 04-02-2010, 09:29 AM   #9
plus2ss's Avatar
Chassis braces! Thats the only thing ive broken more than once, but its hard to have something not break when you get hit at full speed. Lol. The rc8b is very durable, it just depends on how much you wreck.
plus2ss is offline   Reply With Quote
WHAT WOULD BE THE BEST 1/8 BUGGY/TRUGGY KIT TO GET???? gettinbrushless Electric Off-Road 21 02-15-2010 10:24 PM
what whould be a good racing buggy for the price slasher man Nitro Off-Road 61 12-08-2009 06:33 PM
First impression of the RC8. Furadi Nitro Off-Road 35 04-16-2008 05:07 PM
