Old 04-01-2010, 01:01 PM   #1
Trader Rating: 20 (100%+)
Default How do I remove the shield on bearings?
Just need a simple answer as to what tool I need to remove the shield So I can clean out the grease n dirt that r in my tko rubber sealed bearings. I tried using a dull pik but kinda damaged the seal n bent it. Thanks in advance.
Matt Piva is offline   Reply With Quote
Old 04-01-2010, 01:05 PM   #2
jpz_67's Avatar
Trader Rating: 56 (100%+)
I just use an exacto blade or hobby knife. I get the blade behind the seal and just pry it up.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 04-01-2010, 01:10 PM   #3
off road god's Avatar
Thumbs up
Yep. Exacto knife. 5 times outta 10 you will break the very end of the tip off...so I just keep an old hobbico with a broke tip for just that reason.
off road god is offline   Reply With Quote
Old 04-01-2010, 01:26 PM   #4
Peter Martin's Avatar
When you pry it out do it on the large OD of the seal...not the ID.
Peter Martin is offline   Reply With Quote
Old 04-01-2010, 01:51 PM   #5
jammin32j's Avatar
That is correct pry it out using the outer race as a leverage point.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
How do you remove the Bearings? Bighomedog11 Electric Off-Road 9 01-11-2007 05:43 AM
How should I clean my acer bearings? rcnewb2004 Electric On-Road 8 05-24-2005 08:16 PM
best way to clean and grease bearings 2mcgrath Nitro On-Road 8 10-24-2003 07:53 AM
