Old 04-01-2010, 04:21 AM   #46
Originally Posted by fattyalan View Post
what radio do you have?
futaba 3pks fasst 2.4 ghz
team terribles
mbx5rcr34 is offline   Reply With Quote
Old 04-01-2010, 09:01 AM   #47
Originally Posted by mbx5rcr34 View Post
thks & you guys mention the "epa" thing ,how you guys set-up your epa ? as stated early 80-90?? ,i did try that before but not that long cause i can see the servo tray move everytime i applied the throttle (full) ,is that good ?? any input here ,thks
You never want to see the servo tray move at full throttle. That means that you have wayyyy too much travel. You want to be at no more than 90% of full travel on the carb. This is not necessarily 90% epa on your radio. Although you could let the carb open up completely, you want to avoid this from happeneing. You want to give the chassis room to flex without stressing the carb.
TPJ International
071crazy is offline   Reply With Quote
Old 04-01-2010, 09:16 AM   #48
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Remove your air filter. Turn on your radio and receiver. Look down the throat of the carb... and pull your throttle. Back off the endpoint until the throttle JUST opens all the way... beyond that is not needed, and can in fact stress the servo, the carb, etc. (Which is why you see the servo tray move.) That is your 100% point, although the radio may not say it is 100%. To limit to 90% or 80% of that, just set your epa to 90% or 80% of whatever number it shows as your full wide-open setting there... so for example if the throttle shows 90% where the carb is fully open, 90% of that would actually be about 81% on the radio, 80% of that would be about 72% on the radio, etc. Or if it showed 110% epa when the carb is fully open, 90% of that would be about 99% on the epa, 80% would be about 88% on the epa, etc.
Hope that helps.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Indoor Dirt Racing @ RC Performance in Madison squirrel Wisconsin & Illinois Racing 4856 05-11-2008 05:25 PM
Team Orion 3200mAh Race Spec LiPo Nexus Racing Electric On-Road 1772 03-16-2008 08:52 AM
1/8th On Road Losing Popularity? jeffreylin Nitro On-Road 734 09-20-2005 12:25 PM
Fantasy World 2004 Race Season FWR Northwest Racers 1198 11-26-2004 06:07 AM
Tags
eb mods, hot bodies d8, losing races, os v-spec .21, racing
