Old 03-30-2010, 06:18 AM   #1
Default Picco P7R evo carb problem
ok here is the deal, i have a picco p7r evo and love the motor, but i have had problems with the carb sticking as well as alot of guys that bought the same engine, i don't want to buy another stock carb and was wondering if any of you all have a recommendation for a different carb that will fit and work, thanks Russ
speedzone99 is offline   Reply With Quote
Old 03-30-2010, 07:53 AM   #2
I had a similar problem, my first step was removing the carb, and then cleaning/CAREFULLY sandpapering the grooves that are on the barrel and generally working away any tight spots. That helped a little, but it was still inconsistent. I then had a o.s speed carb laying around, so I got the neck of it milled on a lathe to the exact dimensions as my picco carb, and bam, no more tuning issues or inconsistencies with my tune... For some reason, my engine runs better too.... Then again I have a ercm modd on it, so its a killer ither way
grkboy is offline   Reply With Quote
Old 03-30-2010, 07:59 AM   #3
good call on the speed carb, i did notice after i sanded the carb it was inconsistent, i am hoping someone that had the same problem figured out a carb that will drop in, but in will ck for a speed carb and see if i can find someone that can mill it down, thanks
Old 03-30-2010, 08:04 AM   #4
neobart's Avatar
Take out the idle screw mount the throttle barrel in a drill and use some toothpaste to lap it in.
Picoo carbs can be a little to tight in the tolerances, but they are really good carburetors.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 03-31-2010, 07:59 AM   #5
thanks for the idea, i will try it.
Old 03-31-2010, 08:17 AM   #6
Maximo's Avatar
what works really well is to use some 1200 grit Clover lapping paste to lap the barrel into the slide.......I have to do this to the odd Picco carb from time to time....
Maximo is offline   Reply With Quote
Old 03-31-2010, 09:01 AM   #7
i think i have some valve lapping compound, u think that would work, i am not sure what grit it is but it must be pretty fine
Old 03-31-2010, 09:12 AM   #8
RJSI's Avatar
Any links, please Neal.
RJSI is offline   Reply With Quote
Old 03-31-2010, 11:33 AM   #9
Maximo's Avatar
http://www.victornet.com/subdepartme...unds/2225.html
Old 03-31-2010, 12:11 PM   #10
OS Speed versus Axe Cobra X1 evo Jerseyboy Offroad Nitro Engine Forum 222 12-16-2010 10:18 PM
OFNA Picco .21 P7R EVO3 Off-Buggy Engine joydude630 Nitro Off-Road 25 03-27-2009 06:15 AM
Picco Evo 2 settings TXRC8racer Nitro Off-Road 12 11-02-2008 12:50 PM
