Old 03-29-2010, 09:06 PM   #1
Default Pipe and Fuel question Picco Evo3
I was going to use a OS VG 21 (I asked about pipes for it about 2 weeks ago) my jammin but I got a good deal on a New Picco P7R EVO3 .21 tonight so I am going to use it instead.
So I guess that I am back to the pipe question. The track that was have at the longest point has a straight of about 115 feet. It also has a few shorter straights with lots of jumps and short tight "S" curves. I am sure that there is no "Super Pipe" that can do it all but I would like some options from more experianced people to guide me on this as I am still new to the race scene part of this.
Also, I have about 4 new gallons of Byrons Gen2 30% fuel. will this Be ok for this engine or do I need to buy a different head shim for it so it will be compatible with this fuel.
Thanks for the advice and help
-Will
Lomax is offline   Reply With Quote
Old 03-29-2010, 09:25 PM   #2
smb17's Avatar
Send a message via AIM to smb17
On my evo2 I run an 086 pipe. I'd imagine they are pretty similar. Maximo I'm sure can chime in. He knows his stuff.
He always says run the picco plugs on piccos.
smb17 is offline   Reply With Quote
Old 04-01-2010, 08:45 AM   #3
Thanks for the help, Anyone else have any opinions?
Old 04-03-2010, 08:54 AM   #4
I have a clockwerks modded evo 2 and have run the 086 and a jp-4. I prefer the jp-4 but again its a engine modded for more torque so for me its a good balance. As far as the 30% nitro you should be good to go. I run 30% O'Donnels and it works great and yes stick with the ofna/picco plugs in the picco engines.
barrydidntknow is offline   Reply With Quote
Old 04-03-2010, 12:46 PM   #5
Integra's Avatar
You'll be glad you got the Evo 3 over the OS Vg FOR SURE......Significantly better motor in every aspect.
As others have said the 086 for pipe and Stick to the Ofna/Picco plugs....you Wont be disappointed.
Old 04-03-2010, 02:52 PM   #6
mblgjr's Avatar
Trader Rating: 86 (100%+)
The Picco 069 is a good choice as well.
JP3 also works well.
You can still get the Trinity/Picco 069 pipeset for fairly cheap. Very broad, smooth torque curve with reasonable top end as well.
http://www.amainhobbies.com/product_...ine-Tuned-Pipe
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 04-03-2010, 03:50 PM   #7
Default re
I have had several evo2-3 the best pipe I have found for the stock motors is the werks 2013 best all around pipe for the motor if the bottom is too much you can tame it with a jp 4 and maintain the topend on a 5 min qual you should use a hair over a half tank on 30% nitro
toofless is offline   Reply With Quote
Old 04-04-2010, 07:31 PM   #8
Thanks for all the help. This is the kind of information I was looking for
-Will
PISTON Question SERPENT7twenty Nitro On-Road 19 08-14-2009 03:09 AM
