Old 03-28-2010, 01:51 AM   #1
yuppi1's Avatar
Default Loc-tite
what strenght loctite do you guys use?
cheers
RC8T - Reedy 121 VR - Spektrum
MOOLOOLA VALLEY RACEWAY
yuppi1 is offline   Reply With Quote
Old 03-28-2010, 01:59 AM   #2
I use industrial strength red loctite that I get from a tool shop close to my house. It works great especially for engines and motor mounts.
fishymamba is offline   Reply With Quote
Old 03-28-2010, 03:09 AM   #3
yuppi1's Avatar
do you find it is really hard to get the screws out?
Old 03-28-2010, 03:19 AM   #4
shanty140's Avatar
I almost always use the blue strength loc-tight. There are very few things that need Red and can cause more problems then it's worth. I would recommend to use blue strength first and go from there. My motor mounts screws work fine with blue and I have no reason for red.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 03-28-2010, 03:39 AM   #5
gkn0315's Avatar
Trader Rating: 126 (100%+)
+1
Glenn Nail
STRC LCG Slash looking for electronics
1985 Associated RC 10 Novak t4 Trinity Monster Horsepower 27T futaba Jr
gkn0315 is offline   Reply With Quote
Old 03-28-2010, 03:55 AM   #6
GRANPA 67's Avatar
Trader Rating: 32 (100%+)
Send a message via Yahoo to GRANPA 67
loctite 243(blue) is wot i use....
ASSOCIATED RC8B3 , NINJA B02 , HITEC, SANWA, AKA , DHAWK RACING
ASSOCIATED RC8T, NINJA B01A , HITEC, SANWA, AKA, PROLINE , AVID
LOSI 5IVE, ZENOAH 29cc, HITEC, SANWA, DDM, TEAM GONADS, TURTLE RACING
SHUT THE GATE ON THIS ONE , IT`S THE DUCK`S GUTS , IT SUCK`S NITRO..........
GRANPA 67 is offline   Reply With Quote
Old 03-28-2010, 04:14 AM   #7
terribleswiss's Avatar
blue loctite on everything but driveshaft setscrews, use a drop of red
terribleswiss is offline   Reply With Quote
Old 03-28-2010, 07:02 AM   #8
speedy2's Avatar
if you want to loose the locktight apply some heat from an
hot soldering tip for a minute, till you hear it starts to whisle
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 03-28-2010, 07:21 AM   #9
Integra's Avatar
As every one else has said...Blue for 98% of jobs...For thing's you DO Not want coming loose without some effort involved you can use Red.
Now there's which style of Loctite...Gel, Liquid or Stick
I prefer the Industrial style Stick and the Liquid....the Gel never seems to last me long enough to justify the price.
Old 03-28-2010, 08:09 AM   #10
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I use red stick loctight on pretty much everything. I never have problems getting screws out when I want them to. Worst case scenario is you will have to heat it up a bit to pop it loose. I will say that screws never come loose with this stuff unless you want them to. I use a very little bit of it on everything. I like the stick because you can control how much you put on the screw much easier than with liquid. I also find the stick stuff is not quite as strong as the liquid, which in this case is a good thing. Only place I use the red liquid is on CVD set screws.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 03-28-2010, 08:22 AM   #11
Trader Rating: 33 (100%+)
I use blue on metal to metal only, never put threadlock when you screw into plastic. As far as motor mounts go, I use blue locktite when mounting the motor mount to the chassis. When I mount the motor to the motor mounts I use lock washers, that way I only have to set gear mesh once. Just use a ball end hex wrench to remove the four screws holding the motor into the mounts to do clutch or motor maintenance.
Mike
mikal is offline   Reply With Quote
Old 03-28-2010, 08:24 AM   #12
Originally Posted by mikal View Post
I use blue on metal to metal only, never put threadlock when you screw into plastic.Mike
Why?
I did :S
c9311 is offline   Reply With Quote
Old 03-28-2010, 08:36 AM   #13
Originally Posted by c9311 View Post
Why?
I did :S
When you screw into plastic for the first time, you are creating "threads" in the plastic. If you use threadlock in plastic, when you remove the screw you will just strip the "threads" you just created instead of backing the screw out.
Mike
Old 03-28-2010, 08:38 AM   #14
Mike
Not to mention loctight won't bond to plastic, and in some cases can even eat away at the plastic. Loctight + plastic is a no, no. If you must use something in plastic, use a small drop of CA tire glue.
-Koby Kubrin-
Old 03-28-2010, 08:56 AM   #15
i use it as gear lube and sometimes my tranny locks up...? maybe ishould use blue too.
cannibal corpse is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 45705 08-13-2017 01:43 AM
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
