Old 03-25-2010, 06:19 AM   #1
RC-ZOMBIE's Avatar
Default Hudy 1/8 droop blocks do you need them if your using the setup station?
Do you realy need them?
Associated~Tekno~Mugen
RC-ZOMBIE is offline   Reply With Quote
Old 03-25-2010, 10:47 AM   #2
lewis666's Avatar
Send a message via MSN to lewis666
i think that they are far to expensive for what they are. i just cut some wood to 30mm high (same as hudy blocks) and use them for my set up station
Durango DEX410R, BCE Losi 8ight 1.5 (radical 621t), Durango DESC410R on the way!
radical engines- www.gotnitroonline.com
Got nitro team driver
lewis666 is offline   Reply With Quote
Old 03-25-2010, 10:50 AM   #3
If you're using the setup station you will need droop blocks.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 03-25-2010, 10:56 AM   #4
pickle311's Avatar
Trader Rating: 31 (100%+)
I used the ones that INtegy makes for 1/8 scale. They are too tall for the setup station so I flip them on the side. They are 41mm tall on the side and are perfect for the setup station and closer to the actual ride height than the hudy blocks.
pickle311 is offline   Reply With Quote
Old 03-25-2010, 11:39 AM   #5
RC-ZOMBIE's Avatar
I do have the Hudy 1/8 setup station, but I run full droop. Here is why I ask because when I use the setup station and set camber at -2 degree all the way around on my RC8TCE and then check it with the RPM monster camber gauge it says -1 degree, am I doing somthing wrong?
Old 03-25-2010, 01:17 PM   #6
LMB
Oh dear, you have just opened a can of worms here!!! I am not playing this time!!!
LMB is offline   Reply With Quote
Old 03-25-2010, 01:20 PM   #7
Trader Rating: 21 (100%+)
+1
TopGearRC is offline   Reply With Quote
Old 03-25-2010, 01:59 PM   #8
The idea of the blocks is so that you are always setting your camber and toe at a consistent point. If you then check again at ride height, it will of changed.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 03-25-2010, 02:03 PM   #9
RC-ZOMBIE's Avatar
Ok, so setup station reads -2 and hand held camber gauge reads -1 so which is it?
Old 03-25-2010, 02:13 PM   #10
doesn't really matter, just use the same gage every time you check it, I setup my cars on the Hudy station after every race weekend at home, and use a plastic rpm gage at the track but just to make sure booth my sides are equal.
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 03-25-2010, 02:18 PM   #11
RC-ZOMBIE's Avatar
Do you use the blocks and hight gauge?
Old 03-25-2010, 07:16 PM   #12
+1 I run my ride height at 28mm, so that's what I set my camber/toe at. I took the time to make a wooden block that was 28mm, only to find out from my brother that a Hitec servo box w/ the lid cut off measures exactly 28mm. Go figure
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 03-26-2010, 04:34 AM   #13
RC-ZOMBIE's Avatar
So all you really have to do is set your ride hight then drop the car down from 6-12" and use the RPM monster gauge to set camber, correct? If you use the 30mm blocks and set your camber to 30mm ride hight when you take it off the setup station and set your ride hight to where its suppose to be you will have to re adjust you camber right?
Old 03-26-2010, 09:31 AM   #14
lewis666's Avatar
well i cut them to 30mm because that is what the hudy ones are and they must be that height for a reason. but having the blocks the same as ride height would give a very accurate reading of the camber because that show how much camber there is when on tyres and fuelled for a race
Old 03-28-2010, 07:45 AM   #15
RC-ZOMBIE's Avatar
TA-05 ver.2 RepaF1 Electric On-Road 2704 05-06-2017 05:25 PM
Hudy Set Up Station mudboger07 Nitro Off-Road 32 01-28-2010 08:15 AM
Getting out of Touring Sale!!! jaysimpson R/C Items: For Sale/Trade 24 07-03-2006 07:39 PM
