Old 03-25-2010, 08:04 PM   #31
Originally Posted by wrayth View Post
That picture works. but move your eyes from the throttle linkage to the hoop on the break cam. Where the linkage slides in and out through the hoop. it keeps getting bound.
I used to have a problem in that area. My problem was that the brake arm would extend while I was on the throttle. When I let off the throttle the end piece would get caught on the top center diff mount causing my throttle to hang a little.
Franchise is offline   Reply With Quote
Old 03-25-2010, 09:01 PM   #32
toobad4u's Avatar
Trader Rating: 93 (100%+)
Some one hit on this already a little bit. Try loosening the bolt/screw that attaches your 2 brake linkages to the servo arm. Make sure there is some free play in there. It might be too tight, and cause some binding at that point, which in turn will not let the rod move around freely in the brake hoop on the center diff.
Stephen
Mihabi RC Your Hometown Hobby Shop.
(850) 914-2815
toobad4u is offline   Reply With Quote
Carb return Spring. hdcruzer Nitro Off-Road 19 10-07-2009 02:54 AM
throttle return spring spudly12 Nitro Off-Road 10 10-24-2008 02:32 PM
Break in stand Judge Joe Brown Nitro Off-Road 50 12-20-2007 06:21 PM
Radio throttle/steering return springs ChrisP Electric On-Road 7 04-12-2004 07:30 AM
