Old 03-24-2010, 06:32 PM   #1
Default tuning woes...
first off i searched and found some informative stuff but still cannot get this guy to stay running.
i have an xtm xterminator with a .21 engine
if i hold my thumb over the exhaust for a few pulls of the starter its fire up and run for a min then if i give it a lil throttle itll die.
having to hold my thumb over the exhaust leads me to beleive its running lean but white smoke and a little unburned fuel is pouring out of the exhaust.
i set both needles back to factory settings and no dice.
i cant get the high side dialed in like all the tuning threads ive read say to do cuz when i try to take off, even feathering the throttle, she dies abruptly.
any input?
lksdG2 is offline   Reply With Quote
Old 03-24-2010, 06:53 PM   #2
jjshbetz11's Avatar
Does it bog down when you take off befor it dies?
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
jjshbetz11 is offline   Reply With Quote
Old 03-24-2010, 06:56 PM   #3
it's loading up with fuel. Lean the low speed needle a little at the time until it takes off without hesitating
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 03-24-2010, 07:53 PM   #4
chewie219's Avatar
So, I have had similiar problems. The first thing I did was check the glow plug. I changed mine out in and it worked great. Something else I learned was not to flood the engine. I was running in to this problem a lot and it was my fault for priming to much. The other thing that I did with a different engine that was giving me a hard time was to check to make sure the idle needle is set right. On my Force .25 it is set with about a 1/8" gap, maybe a little less. It idles really good now. Hope this helps. I am still in the learning phase, but I know your pain.
Chewie219 - OFNA 9.5 Buggy, RC10Gt w/OS .15
chewie219 is offline   Reply With Quote
Old 03-24-2010, 07:59 PM   #5
losi_racer's Avatar
Trader Rating: 25 (100%+)
check idle gap and the low end sounds rich. holding the thumb on the stinger forces fuel into the engine, you should only have to do this if your engine hasnt been ran in a couple hours or longer.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 03-24-2010, 09:22 PM   #6
yes it does
cool, will try that tomorrow after work
i will check the plug, the tank doesnt have a primer on it so i was plugging the exhaust to force fuel through the lines
cool thank you sir, but what is the stinger? if thats the exhaust tip i was doing it cuz it was the only thing that could get it to start
Old 03-24-2010, 09:26 PM   #7
losi_racer's Avatar
yes, the stinger in the end of the exhaust that youve been plugging. lean the bottom end out. its to rich, you will have to lower idle when leaning the bottom
Old 03-24-2010, 10:25 PM   #8
ok, that explains why it wouldnt start unless i did
Old 03-27-2010, 01:56 PM   #9
got her running, turns out the main needle wasnt open enough.
we figured it out cuz it would start when primed but only run till the fuel that was dropped into the opening had burned off. just deduced from there.
thanks for the help though everyone!
New Engine Woes, Please offer me some expert advice! memphis212 Rookie Zone 16 05-09-2007 09:58 PM
Newb with rs4 woes rivbluenoma Rookie Zone 10 07-18-2005 09:39 PM
new engine woes (novarossi rs12) packetdreamer Nitro On-Road 39 08-07-2004 09:14 AM
