Old 03-24-2010, 03:04 PM   #1
Trader Rating: 26 (96%+)
Default 8ight front center diff cup getting very hot
I have a Tekno 8ight-e. The buggy is very dialed, but I have noticed that the front center diff outdrive gets super hot. I haven't fealt around the other cups, the spur is luke warm. The diff works great, but I don't want to have a failure because the diff casing melts. Is this normal, from I guess friction w/ the cvd, or is there something I need to change. It has fresh 5k fluid in the diff.
party_wagon is offline   Reply With Quote
Old 03-24-2010, 04:22 PM   #2
neobart's Avatar
Check bearings and front brake disk(Tekno uses mechanical brakes right?).
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 03-24-2010, 04:27 PM   #3
Integra's Avatar
E-buggy's spool the front tires quite a bit and working that front bone pretty good....i would think unless its Super hot to the touch its nothing to be concerned about.
Old 03-24-2010, 05:20 PM   #4
Trader Rating: 17 (100%+)
check your outdrives very carefully it maybe bent.. my moneys on it
RICK ENDLER
Hot Bodies Racing
www.greathobbies.com
SKY RC
Exotek
endler is offline   Reply With Quote
Old 03-24-2010, 06:08 PM   #5
The rest of the diff is luke warm. The front cup is very hot to the touch & this is coming from a guy that has done a good bit of labor w/ hot things. The cvd & outdrive are in brand new condition, but there is some play in that bearing that allows the outdrive to move around a little. The bearing spins very freely, but if this slop is causing the issue I will replace it. Are there any other problem areas that I should watch out for? The car has King Headz hinge pin braces & the alum rear bearing guides. The rest of the drive train is pretty much stock.
Old 03-24-2010, 07:01 PM   #6
i temp gun my clutch's, looks like i will start doing the outdrives too.
wont' hurt to change the bearings.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 03-24-2010, 07:13 PM   #7
Integra's Avatar
curious on your temps ? ive seen a Fioroni Turbo Slider hit 300+
Old 03-24-2010, 07:50 PM   #8
losi_racer's Avatar
Trader Rating: 25 (100%+)
ive touched my clutch bell before when i was running avid clutch bearings, sometimes they would blow before my race during practice even when they were new. and i burned my finger immediately upon contact
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 03-24-2010, 08:05 PM   #9
Integra's Avatar
Avid's are just fine and dandy if you ask me....something in your set-up must have been causing the high temp's and bearing failure.
Old 03-24-2010, 08:23 PM   #10
losi_racer's Avatar
i use avid for wheel bearings, there great. but for clutch they were hit and miss and im not the only one at the pit who thinks that. i recently when to tko ceramic bearings for the clutch(i know nick, u hate them) and i love them. just dont spray them out with electric cleaner. they fail very fast
Old 03-25-2010, 07:41 AM   #11
Integra's Avatar
I never said i hate the TKO's...i run them quite frequently on my losi clutch set-up....I just feel that the Avids are up to the task if everything is set-up properly.
Old 03-25-2010, 07:47 AM   #12
Frank L's Avatar
Trader Rating: 148 (100%+)
Inhabe been using the tko $1 bearings and they seem to hold up better than the avid revolutions. They are a double rubber low contact bearing. The diffs are still very smooth after a gallon. I think I'm using tko all around now except the clutch I trust losi HD bearings in the clutch they don't let me down.
Old 03-25-2010, 07:59 AM   #13
Trader Rating: 28 (100%+)
i've been using avid bearings all over my losi 8 b and t and i change the clutch one about every 1 -1.5 gallons and once o year in the rest of the car
overboard is offline   Reply With Quote
Old 03-25-2010, 09:32 AM   #14
az00lude's Avatar
Center diff in electric cars get hotter due to diffing action with higher power. I'd think about going higher in diff oil to control unloading of power to the front wheels.
Xray xb808
az00lude is offline   Reply With Quote
Old 03-25-2010, 09:41 AM   #15
Integra's Avatar
I felt mine become real tail happy when i tried to go up in the center...tried 7 and it was wheelie city when you nailed it Vs normally being able to deal with the front end being light but not wanting to pull the front wheels physically off the ground.
