Help please, stuck in gear?
Hi there, i am trying to start my smartech buggy nitro. And when i pull the rope, the wheels are spinning, why? How do I get it in neutral so the wheels are not spinning when I am trying to start it. This happened to me once before, and I just wheeled the car backwards and it fixed it. But not this time
please help
thanks
please help
thanks
this car is brand new, only run a couple times for very short periods.
Can you elaborate? Is that the only thing it can be? Do you know what parts to replace? I am very new to this, and want to have the car running for when the snow is gone.
thanks!
thanks!
Is there anyway to manually put it in nuetral for the time beiing?
You're clutch bearings are locked so when you are pulling the rope the clutch bell is turning with the crank and turning the wheels it's a cheap fix just a few bucks for new bearings
thanks for your help, do you know if the bearing, is called the rolling bearing? How many of these bearings is there suppose to be, only two right?
I am on rcworlds website, and if you go to smartech parts for the speedy tiger. It shows a picture of the two bearings I think i need but doesnt say what they are only shows the picture, looks exactly what i think i need.
Then below that is another part: a picture of 6 bearings, that look nothing like i think i need, but have the measurement of the bearing I am looking for 10x5x4. So i am confused, the picture looks more like a washer, plus why do they have 6?
I work in a hobby shop and have seen 6 of these buggy's all with the same issue, barely ran and wont start but the tires want to spin when pulling the starter cord. What i have found on every one of those vehicles was that the clutch was siezed to the clutchbell so dont be surprized if the clutch comes off when you pull the bell off the motor.
Sorry for the late reply, I had no internet, got it fixed today~
I do have a manual for it, its not the best though. I talked to the guy at RC world and he thinks the clutch is seized to the clutch bell too.
Maybe i will just list this up on ebay broken and buy a real RC. I just bought this to see how I would like it. I do love it. My car did run good though, i never had any troubles getting it started or keeping it running, was tuned pretty good.
Maybe I will fix it, I have never really took apart these before, but how hard can it be? lol I have done lots of work on quads and vehicles, all by the book though.
These types of clutches are centrifical(sp) so unless it's started up and under throttle, it's always in "neutral". Fot the clutch shoes to seize to the bell would require massive heat or slippage to cause the heat. I would highly recommend getting a stable brand of 1/8 buggy. Most of these type of headaches have been worked out with a quality manufactorer. If you are going to stick with your brand, pull the clutchbell, flush and lube the bearings, pull the shoes and see if they stretched where they go on the poles. Sand the inside of the clutchbell and clean well. Get new shoes and springs.Was your buggy smooth in the power delivery or come on strong?
Just fix it. Any vehicle you get is going to require you to work on it.
Why would you sell as broken when you can spend a little money and a little time and sale it as RTR
