Old 03-22-2010, 05:55 PM   #1
rotarynut's Avatar
Trader Rating: 30 (100%+)
Thumbs up Alternative products
While walking around the local Home Depot the other day I ran across a couple of products that some might be interested in as an alternative to use in our hobby, both are "Blaster" brand, one is the citrus based degreaser, I used it yesterday on my buggy.. it did a fine job cleaning it. It's similar to Kalguard degreaser which is a fine product, I was running low on it so I decided to try it out. The other is a dry lube which contains PTFE = Teflon which has the lowest coefficient of friction against any solid. It comes out clear then dries to a white powder, I sprayed every moving part on my buggy...CVD's, rod ends, suspension pivot points,even the spur gear and clutch bell gear, BIIIG difference... it glides effortlessly now. So if you're low on supplies and/or money try these out.
http://www.blastercorporation.com/The_Dry_Lube.html
http://en.wikipedia.org/wiki/PTFE
Robert S.
CEN Matrix R2 1/8 Buggy, Novarossi Toronero H.E.S.Tuned 9901/41021, Hitec HS-7955TG/5625M
Losi 8ight-T 2.0,BCE chassis, Novarossi 21-7 FMS H.E.S. Tuned 2084SS/41021
Hitec HS-7955TG/5645MG - Stickman Batteries -Airtronics M11x
Traxxas Summit 1/10 on Gens Ace 2S lipos 5000mah
rotarynut is offline   Reply With Quote
Old 03-22-2010, 06:45 PM   #2
I like this thread
Another lube worth using is White Lightning Clean Ride (http://www.whitelightningco.com/products/index.htm), I've used it on my mountain and BMX bikes for years with excellent performance. Basically it's a wax-based dry lube that doesn't attract dirt yet is super slick, I'd highly recommend it.
Tamiya Hornet OG
Ofna Ultra MBX Pro
Associated RC8B FT
tromoly is offline   Reply With Quote
Old 03-29-2010, 06:30 PM   #3
rotarynut's Avatar
Default lexan polish
Hey guys,did a search on The find.com & found this, I need some to clean up my lid,will get some tomorrow if they have it in the store and let you know how it works.
http://www.homedepot.com/webapp/wcs/...-1609763-_-8oz Plastic Sheet Polish&SID=tfc_-_16_8_100329_2ff777d56c8f381e8c39d6e76a84597d&AID= 10368321&cj=true&locStoreNum=131&marketID=1
Robert S.
Old 03-29-2010, 06:55 PM   #4
Eric Thompson 2's Avatar
PB Blaster is good for just about everything, on anything.
Serpent America
Eric Thompson 2 is offline   Reply With Quote
Old 03-29-2010, 07:15 PM   #5
moeman's Avatar
Trader Rating: 26 (100%+)
Different idea, same difference, I use liquid electrical tape for sealing nitro motors, it is fuel resistant and peels off rather easy when you need to. I only apply it on the outside of the carb seal, backplate, etc...apply it with a small brush or q-tip.
moeman is offline   Reply With Quote
Old 03-30-2010, 05:20 PM   #6
rotarynut's Avatar
Thumbs up lexan polish
I called Home Depot today, the polish I found is only sold online, but I did go to Advance Auto and picked up a bottle of Meguair's "PlastiX" it'a clear plastic cleaner and polish, I just polished my lid, it came out good,it leaves the lexan smooth as silk.the windows were hazzy and dull...not no more,you can see thru them now.
http://www.meguiarsdirect.com/produc...?T1=MEG+G12310
Robert S.
Old 03-30-2010, 05:39 PM   #7
pickle311's Avatar
Trader Rating: 31 (100%+)
For cleaning bodies, I use Honda polish. I've used it for years on my motorcycles and it works great. One day I was cleaning a body and saw the can sitting there so I sprayed it down. Been doing it ever since. It's a wax based polish, I find that my body stays a lot cleaner now as less dirt sticks to it.
Also, I use a Teflon based chain lube for my CVDs and moving parts. I figure if it's good enough for the chain on my race bike, it's got to be good for the truggy. Works great.
I also use K&N air filter oil. I had the can already so why not use it.
And the best for last. Next time you need some simple green, go to walmart or autozone and pick up a gallon of purple power. 1 gallon is cheaper than a small bottle of simple green and it's probably twice as strong. I've been using it for the last 10 years and I'm still amazed at how well it works. I'm dilute it 50/50 with water so it's not so bad. Be careful, I have seen it strip anodizing off like it wasn't even there if let sit too long.
pickle311 is offline   Reply With Quote
Old 03-30-2010, 06:23 PM   #8
I know it's pretty common, but simple green is the best all around cleaner for RC. It's good for general buggy cleaning, body and tire cleaning, and will act as a slight traction compound. You can get a gallon of concentrated simple green for around 15-20 bucks at HD. It will last forever. Also, my brother found some graphite spray at the hardware store(can't remember the name) that works great on cvds and such. For sealing engines, gray high torque silicone is great.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 03-30-2010, 07:14 PM   #9
jammin32j's Avatar
Miniracer23's brother here. The graphite spray he is talking about is Graphite Extreme and it is made by jig-a-loo. It is a bit messy but works great.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 03-30-2010, 07:21 PM   #10
pickle311's Avatar
Who told you about my last job?
IDM Products? rcrevolution Onroad Nitro Engine Zone 717 03-03-2013 02:52 PM
Skyline Racing Products Racing4Evo Nitro On-Road 790 07-19-2009 02:49 PM
Brahma Racing Products "ULTIMATEPOWER" Team and Company Discussions 3818 03-27-2007 12:57 PM
