Old 03-22-2010, 04:49 PM   #1
Default help with wraps
ok maybe dumb question but do you cut your holes before or after putting on wrap? Anyone use windex so you can adjust vinyl a little better?
Falcon422 is offline   Reply With Quote
Old 03-22-2010, 04:58 PM   #2
Trader Rating: 30 (100%+)
have your body completly cut out before putting on the wrap. The only thing i use putting them on is a little heat
gofast072 is online now   Reply With Quote
Old 03-22-2010, 05:03 PM   #3
ok thanks. then do you use a blade to trim the vinyl around the holes?
Old 03-22-2010, 05:06 PM   #4
jkas10's Avatar
Trader Rating: 121 (100%+)
i cut the whole body out first to include the wheel wells, engine hole, tank fill hole, etc. not body mount holes. Then, i paint the inside of the body a solid color if the wrap will have gaps. Then I wrap without windex (Fastlanes are so sticky, a little windex will not let you slide it anywhere...) Heat gun it a bit for permanent adherance.
Then, I ream the body mount holes and do any small finish/trim/dremel work that might be necessary.
Jeremy Kasten - Cole's Pitman! (Dad); Kasten Racing: www.facebook.com/kastenracing
THANK YOU Sponsors: Mugen Seiki; REDS; AKA; Leadfinger Racing; NitroPro Fuel; RC Addiction Products; Dialed-RC Hobbies; Ben Brocato Designs (BDB); PT RC Racing Oils
jkas10 is offline   Reply With Quote
Old 03-24-2010, 10:01 AM   #5
Sprinkler's Avatar
Trader Rating: 28 (100%+)
Send a message via ICQ to Sprinkler
I paint the inside of the body first. Then I wipe the outside of the body down with alchohol. Then I apply the wrap. I use a hair dryer to get it in the hard corners and curves with no problems. They stick really well too.
I use the Fastlane-Graphix wraps.
John McGinty
Mugen Seiki Racing/ JConcepts/ Tekin/ Absolute Hobbyz/ Advantage Racing Products/ Byron Fuels/ Competetion Heat/ NovaRossi/ Airtronics/ Stickit1racing.com/ Murnan Modified Motors/ M2C Racing
Sprinkler is offline   Reply With Quote
Old 03-24-2010, 10:05 AM   #6
+1 - just take your time.......... I did use windex for the big parts, then heat gun........
I'm not sponsored so it does not matter what I put here.
Shuming is offline   Reply With Quote
Old 03-24-2010, 10:13 AM   #7
MontanaMaxx's Avatar
it sounds like a big pain in the a$$ to me
MontanaMaxx is offline   Reply With Quote
Old 03-24-2010, 10:29 AM   #8
Trader Rating: 74 (100%+)
DO NOT USE WINDEX, windex breaks down the glue. If anything use a mild soap mixed with some water.
skerry1 is offline   Reply With Quote
Old 03-24-2010, 11:16 AM   #9
bcr500's Avatar
Trader Rating: 34 (100%+)
I would use 97% water and 3% johnsons baby shampoo instead of windex.
MBX6R
XRAY XB808
NOVAROSSI
bcr500 is offline   Reply With Quote
Old 03-24-2010, 11:22 AM   #10
cdbias's Avatar
I just put some wraps on before cutting out or painting the body. There were a couple things I liked about this method.
1. There is more of the body to hold on to when it's not precut.
2. Without paint on the inside you can look through the body to make sure that all of your edges have a good seal.
I didn't use Windex or anything. The Fastlane wraps are pliable enough that you can make the wrap flex/bend the way you need and you can peel them back a little without leaving glue on the body. (Some wraps are so thick that you just can't make them work in tight corners)
Of course, it might just be a personal preference issue.
Thank You,
Casey Bias
Tekno RC | Jconcepts| Trinity | Hobbywing | MKS Servos | Elevation Sports | Code 3 RC |
cdbias is offline   Reply With Quote
Old 03-24-2010, 04:12 PM   #11
bcarter007's Avatar
Trader Rating: 96 (100%+)
chad at fastlane says to use warm water and a little soap in a bowl then dip ur wrap piece by piece in the bowl to slide it into place then use a hair dryer not a heat gun
Rangers Lead the Way!! Team Hotbodies Driver Hara D8 OS Speed XZB Hara Ed D8T OS Speed XZB Hara Ed Ve8 Tekin RX8 1400kv UP Grade Graphics Hitec DX3R PRO RayAracing.com RAPICON 30/9 Race Blend Jammin SCRT10 4x4 Tekin RX8 4.5T SMC Hotbodies Tires Thankyou HPI-Hotbodies & Pro-Line
bcarter007 is offline   Reply With Quote
Body wraps, whats the point? casevac Nitro Off-Road 120 12-27-2011 08:36 AM
Coupon codes for online shopping to help keep things cheap in 2010! ABURTON Nitro Off-Road 296 06-03-2011 09:34 AM
need help!! surching for a balancer cable t4usee Electric Off-Road 7 02-13-2008 04:27 PM
Easy Wraps andrewdoherty Painting, Designs, Graphics and Photography 25 01-05-2006 08:55 PM
