Old 03-21-2010, 10:02 PM   #1
kodiakbear7070's Avatar
Send a message via MSN to kodiakbear7070
Default idle screw and lsn
Does these two work together and how would I adjust them to get a good idle I have a new motor and I had to open the carb up a lil bit to get it to run now that it is about to be tunned how would I bring the needles down to accomplish this and would I need to richen the hsn or lean the hsn
kodiakbear7070 is offline   Reply With Quote
Old 03-21-2010, 10:09 PM   #2
MontanaMaxx's Avatar
as you lean the lsn then your idle will go up needing to close the carb a bit riching up the lsn lowers the idle and will need to open the carb to keep it running so when ya hit the sweet spot any adjustments will be on both needles lsn in idle screw out and vise versa
MontanaMaxx is offline   Reply With Quote
Old 03-21-2010, 10:15 PM   #3
Thanks that is what I have been doing but was questioning what I was doing so I stopped before I created a costly mistake
Newbies Queries - Ask and you shall be answered! renben Singapore R/C Racers 4617 07-21-2017 11:28 PM
O.S. 21 VZB High Idle Issue??? everyjuangohome Nitro Off-Road 9 03-25-2009 12:17 PM
os VSPEC will not IDLE/tune, please help patrick21x Nitro Off-Road 26 08-04-2008 12:20 AM
