Old 03-21-2010, 01:22 PM   #1
Trader Rating: 119 (99%+)
Default low speed needle
how exactly does the low speed needle fuel line pinch test work? and where do you pinch the fuel line, right under the inlet to the carb, an inch before that, does it matter?
skoalisbad4me is offline   Reply With Quote
Old 03-21-2010, 01:58 PM   #2
Charles Godwin's Avatar
Just lean the low speed needle until it starts to 'choke' when you give it full revs. Then richen in a 8th 2 a quarter...i really don't understand the pinch test method. Too many slight variables in where u hold the fuel line.
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 03-21-2010, 03:07 PM   #3
it allows the engine to burn what ever fuel is left in the engine. After the engine has been idling and the lsn was to lean and you pinch the line there wont be any fuel left in the case to keep it running so it will die very fast without going through the lean stage (reving up a bit)
If it was to rich and you pinch the line, the engine will keep going and rev up a bit as it burns off the residual fuel and goes through the to lean stage.
If it is just right it should rev only very slightly for a couple seconds.
if it rev's for more then a couple seconds and higher rpm's = to rich
If die's off very quickly without increasing at all = to lean.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 03-21-2010, 04:26 PM   #4
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
ya what he said ^^
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
