Old 03-22-2010, 06:55 PM   #16
plus2ss's Avatar
Using a steel flywheel would make the low end smoother, and less like an on-off switch. It might help.
plus2ss is offline   Reply With Quote
Old 03-24-2010, 05:27 AM   #17
barty1989's Avatar
Send a message via MSN to barty1989
my base setup
easy 2 drive loads of traction
suited for loose tracks
or low traction dry tracks
also works well on higher tration tracks with standard droop.
Nathan Bartholdt
thanks to
Rc King Hobbies/ Sworkz/ Alpha Plus/ Aplus/ Ultimate Racing/ Meccamo/ Beta racing tyres
barty1989 is offline   Reply With Quote
Old 03-24-2010, 06:52 AM   #18
mudboger07's Avatar
Originally Posted by barty1989 View Post
my base setup
Wow you use 10K, 10K 7K in your diff, I had to go down to 5K in the center diff in my sons to help it out, by going up I thought it would make it worse?
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 03-24-2010, 03:00 PM   #19
barty1989's Avatar
higher fluids used with over drive gears.
rear pinion is onlya 10t where the front is 13t alows the front wheels to spin faster then the front. alows you tobe able 2 drive ths car hard.
i run 15 000 15 000 10000 in my tamiya
Nathan Bartholdt
thanks to
T1FK05 Set up help!? Onroad Freak Electric On-Road 14 11-01-2007 10:27 AM
Thrust Bearing Question Please TRFTIM Nitro On-Road 26 05-25-2006 06:56 PM
