Old 03-20-2010, 06:32 PM   #1
Trader Rating: 119 (99%+)
Default burning through Glow Plugs
so what would cause my motor to burn through glow plugs so quickly. i have a Ninja JX21 that is about 2 1/2 gallons old and up until last night has been running flawless and was actually still on the original factory glow plug. well just last night i went through 3 glow plugs and i cant figure out why. the tune didnt change and the car was running strong all night but i had to but a brand new pkug in each time i fired up the car cuz they were burnt out. and i know it was a plug because as soon as i put a new one it she fired right up. PLEASE help plugs arent cheap and cant afford to keep going through them like that
by the way i am running an OS P3 plug in the motor and its in an xray 808 with an os 2050 pipe
skoalisbad4me is offline   Reply With Quote
Old 03-20-2010, 06:40 PM   #2
tc5 man's Avatar
if your eating throw plugs like that, than i think you might have leak somewhere.
Old 03-20-2010, 06:41 PM   #3
Davidka's Avatar
Trader Rating: 75 (100%+)
check your rod for slop, that usually causes plugs to blow quickly. OS rod bushings wear somewhat quickly.
Old 03-20-2010, 06:42 PM   #4
no leaks, motor is all sealed up. if there was a leak the motor just wouldnt run the way it does. it screams down the back straight, drops to a perfect idle every time the tune is very good and after a 15min A main it came off the track right at 221. the motor runs flawless except for the fact that i cant keep a plug. and this just started last night
Old 03-20-2010, 06:57 PM   #5
i had a faulty plug in my jx not to long ago. Put it in started once then burned out.
Faulty plug. Dont' know, but maybe you got a bad batch?
are you absolutley sure it's the plug? Did you check them all when you had them out of your engine?
Maybe you got some freak fuel?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 03-20-2010, 06:58 PM   #6
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
good chance the front bearing is bad,,, common in OS engines. has the engine "backfired" at all?
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 03-20-2010, 07:19 PM   #7
rotarynut's Avatar
Trader Rating: 30 (100%+)
Default glow plugs
I've had the same problem with my LRP.28, the orig plug lasted a full gallon, since then I've had issues with them, different brands,colds..mediums, I think what was doing was running the engine too lean, causing it to burn the plugs if it ran out of fuel or pinched the fuel line to shut it off. I'm runnung LSN a little richer than I was before,have run about a quart of fuel thru with this plug, I'll keep my fingers crossed.
Robert S.
CEN Matrix R2 1/8 Buggy, Novarossi Toronero H.E.S.Tuned 9901/41021, Hitec HS-7955TG/5625M
Losi 8ight-T 2.0,BCE chassis, Novarossi 21-7 FMS H.E.S. Tuned 2084SS/41021
Hitec HS-7955TG/5645MG - Stickman Batteries -Airtronics M11x
Traxxas Summit 1/10 on Gens Ace 2S lipos 5000mah
rotarynut is offline   Reply With Quote
Old 03-20-2010, 07:29 PM   #8
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
ya what he says...... hi dave....
also a rich lsn and a very lean high needle will cause this... causing a false normal idle.. like rotarynut stated do a pinch test on fuel line. around 4 secs then die is what you are looking for.... for indoor nitro temps should be 180-200 if outdoor then temp is good.... jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 03-20-2010, 07:35 PM   #9
dja
If you are plugging the exhaust when you shut your engine down this compresses the filament in the plug and causes it to fowl almost every time. You have to shut the engine off by stopping the fly wheel, had to do this when I switched to P3's.
dja is offline   Reply With Quote
Old 03-20-2010, 07:45 PM   #10
madweazl's Avatar
Is this an OS thing? I always kill my engines by plugging the exhaust and I've only had 1 plug fail.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 03-20-2010, 07:48 PM   #11
Jaz240's Avatar
Trader Rating: 52 (100%+)
Plugging the exhaust stinger is also a great way to suck all the dirt out of your air filter and right into your engine
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 03-20-2010, 08:31 PM   #12
I never ever shut down the car by plugging the stinger. Always stop it with the flywheel. I checked the rod earlier in the week and not a bit of play. I will do the fuel line test. Maybe my tune is off. But my tune is good, any other suggestions? Maybe bad bearings?
Old 03-20-2010, 08:33 PM   #13
jpalessi's Avatar
Joe Alessi
www.Lucky7RC.com
Old 03-20-2010, 08:55 PM   #14
Felix's Avatar
If spanking plugs came outta no where try this...
Take off the head and look at the button and check for detonation(the button will look rough and so will the piston) if thats happening then thats usually from a bad bearing or con rod... and will spank plugs like crazy... hopefully you didnt drop a coil because that is common when engines get like this...
Serpent 811-T TE CLOCKED BONITO
Serpent 811-B TE SPEED
Felix is offline   Reply With Quote
Old 03-20-2010, 09:04 PM   #15
jpalessi's Avatar
+1 most likely a bearing in this case.. OS
its sucks a $15 dollar bearing causes hundreds in pre-mature failures.
GO TKO!
Joe Alessi
www.Lucky7RC.com
Burning glow plugs?? tylerp_2000 Monster Trucks 21 05-14-2009 05:50 PM
Eating through glow plugs today? A costly day.. Why? Mpowerz Nitro Off-Road 31 01-05-2008 09:20 PM
OS P3 Glow Plug Problems Jon Kerr Onroad Nitro Engine Zone 8 09-26-2007 07:32 PM
Tax Return Burning A Whole In Your Wallet Mr. Shookie R/C Items: For Sale/Trade 21 02-26-2005 07:47 AM
