Old 03-19-2010, 02:03 PM   #1
Default Air Leak
What are symptoms of an air leak?
NitroAmmo is offline   Reply With Quote
Old 03-19-2010, 02:12 PM   #2
Trader Rating: 119 (99%+)
erratic tune, suspicious random flameouts, engine went from running great one weak to crap the next.
the best way i have found to check for air leaks is to fire up the engine on the box, and then while either blipping the throttle or just barely holding the throttle open steady, spray some break clean or carb clean, whatever you got on the neck of the carb. if the RPMs drop like it is wanting to die or if it does actually die, you are sucking air. if its not on the carb do the same thing on the back plate
skoalisbad4me is offline   Reply With Quote
Old 03-19-2010, 02:12 PM   #3
KThatcher's Avatar
Trader Rating: 64 (100%+)
Going through plugs like crazy and inconsistant tune
- Picco - Triton RC - 818 Designs - Team-CRP - RCRenew.com -
Pro Motion T-shirts -
KThatcher is offline   Reply With Quote
Old 03-20-2010, 08:31 AM   #4
bgballin26's Avatar
I just started having these symptons this weekend with my ninja .21, it has a gallon of fuel through it. It starts revving high when it's at idle, it was tuned great and just started doin it...
bgballin26 is offline   Reply With Quote
Old 03-20-2010, 08:47 AM   #5
Your problem is probably clutch then. Check for burrs or anything that may cause it to hang up. I know the OS engine line has a shorter than average lifespan, but unless you did something horribly wrong, there's no reason to have an airleak in the first gallon.
As for air leak, if your engine wont hold a tune, runs on, and kills plugs* then you probably have an air leak. A bad clutch can cause strange behavior and running on, but if you're killing plugs and the engine is older, you may have a leak.
90% of "air leaks" end up being clutch problems in my experience.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Air Leak or Tune? CraigM Onroad Nitro Engine Zone 7 10-24-2007 10:44 PM
air leak on nitro engine dotmatrix Nitro On-Road 10 11-30-2006 08:13 AM
engine air leak?? oderem Nitro On-Road 13 07-12-2006 01:55 PM
HOW TO CHECK FOR A AIR LEAK? DAVE BERNATH Electric Off-Road 8 08-29-2005 03:12 PM
Nova Rossi engine Air leak or fuel leak? Solara Nitro On-Road 15 01-21-2005 03:00 AM
