Old 03-19-2010, 01:54 PM   #1
Fd2k's Avatar
Trader Rating: 25 (100%+)
Default Engine sealant on New Engine
I have a brand new Ninja Jx.21 engine. Im thinking about putting engine sealant ( Lucky 7 ) on it before doing the break-in. What you guys think... Should i put the engine sealant before doing the break-in or after?
Fd2k is offline   Reply With Quote
Old 03-19-2010, 02:00 PM   #2
David Wall's Avatar
Tear it down, flush with fuel to make sure no contaminants are in there, then seal her up
Retired!
David Wall is offline   Reply With Quote
Old 03-19-2010, 02:03 PM   #3
KThatcher's Avatar
Trader Rating: 64 (100%+)
Heck ya you should seal it and Lucky 7 is the best way to do it...
- Picco - Triton RC - 818 Designs - Team-CRP - RCRenew.com -
Pro Motion T-shirts -
KThatcher is offline   Reply With Quote
Old 03-19-2010, 02:07 PM   #4
Fd2k's Avatar
Default .
So the only part i should put the sealant on is on the engine back plate and on the carb?
Old 03-19-2010, 02:10 PM   #5
jpz_67's Avatar
Trader Rating: 56 (100%+)
When I seal a motor I usually just do the backplate, both sides of the pinch bolt, and base of the carb.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 03-19-2010, 02:14 PM   #6
David Wall's Avatar
The great thing about Lucky 7 is you can use it on all points that could cause a leak. Backplate,Pinch bolt, Carb neck, fuel nipple...etc
Retired!
Old 03-19-2010, 02:22 PM   #7
Racecrafter's Avatar
Trader Rating: 25 (96%+)
+1!
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 03-19-2010, 02:24 PM   #8
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Default L7 Engine Sealant Instructions
L7 engine sealant is intended for external use only. I recommend installing only 1 mount mount screw and mocking up the carb angle etc, then i pull the engine back out, make sure everything is tight and seal up around the carb base, pinch bolt ends, and HSN assembly. NOW when using the sealant you'll find its very thin and easy to work around (wicking) into the tight areas making a good seal. I'll actually apply an excessive amount in one spot and blow on it to help work into tight areas were i can't get the applicator tip. don't be afraid to apply what may look like to much, cause when it drys it shrinks down to a tight coating. Hope this helps good luck!
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 03-19-2010, 02:32 PM   #9
KThatcher's Avatar
What Joe said!!!
Old 03-19-2010, 04:22 PM   #10
Fd2k's Avatar
Default ;
So far it sounds like i should put the engine sealant on my new engine before doing the break-in on it. How long should i wait till it dry up?
Losi 8ight 3.0 / Novarossi P5 / Novarossi Pipe / Hitec servo / GunHill Track ( Ft Knox Park ) / Spektrum / Werks Fuel / Proline /
Old 03-19-2010, 04:30 PM   #11
Integra's Avatar
L7 needs an hour or 2 to cure up pending ambient temp
Old 03-19-2010, 04:32 PM   #12
sluggo_sx8's Avatar
where do you get L7 and is there anything else that would do the job?
sluggo_sx8 is offline   Reply With Quote
Old 03-19-2010, 04:46 PM   #13
jpalessi's Avatar
http://www.lucky7rc.com/l7home/produ...products_id=49
Joe Alessi
www.Lucky7RC.com
Old 03-19-2010, 05:07 PM   #14
Integra's Avatar
there are other alternative's but nothing like L7...its Very liquidy and flows nice depending the part you are trying to seal....there are still some who like a silicone type consistency as their preferred sealant....1 product is Racers Edge Carb sealant or the expensive version Three Bond 1211
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9300 03-27-2017 05:54 PM
REEDY .21 Nitro Engine Kevin Boyle Offroad Nitro Engine Forum 1359 10-08-2014 01:19 PM
v-spec vs jpx.21 engine comparison Bulldawg RC Nitro Off-Road 36 04-23-2009 09:16 AM
