Old 03-18-2010, 07:55 PM   #1
Moderator
Muggydude's Avatar
Trader Rating: 89 (100%+)
Default Deandonizing Revo chassis makes it weaker?
Would deandonizing a traxxas Revo 3.3 chassis make it weaker? Thanks
Muggydude is offline   Reply With Quote
Old 03-18-2010, 08:14 PM   #2
Dale88Jr's Avatar
Its not going to make it weaker but it will expose the allum and make it rust and so on
~Hot Bodies Ve8 Tekin 2050kv MMP 4s 40-80c Futaba 3PL AKA Tires~
~Support Your Local Hobby Shop~
Dale88Jr is offline   Reply With Quote
Old 03-18-2010, 08:28 PM   #3
mudboger07's Avatar
You can clear coat it after so it wont tarnish..
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 03-18-2010, 08:35 PM   #4
MontanaMaxx's Avatar
last time i checked aluminum doesnt rust only iron
MontanaMaxx is offline   Reply With Quote
Old 03-18-2010, 08:57 PM   #5
Anodize is an aluminum oxide coating over the bare metal, the oxide can be dyed different colors before the pores are closed. If you remove the coating, more aluminum oxide will form. What is known as rust is just iron oxide in steel, same kind of concept. The anodize (aluminum oxide) is harder then the bare aluminum or the thin layer of aluminum oxide that will form under normal conditions. It will resist wear better with anodize. It does form a hard layer around a more ductile base metal, but I can't imagine it lends much to the overall integrity of the chassis. Then again, I don't have any experience in RC chassis design.
adirkes is offline   Reply With Quote
Old 03-18-2010, 09:03 PM   #6
Rust is Iron Oxide, as Aluminum doesn't have any iron content you are 100% correct
Go ahead and deanodize the chassis, last year I did the same on a stem and chainwheel (crank sprocket) on my brother's BMX bike and both have held together just fine. Though personally I would clearcoat the chassis after you strip it just to give it a slight layer of protection, doing a rattle can clearcoat should work just fine.
Tamiya Hornet OG
Ofna Ultra MBX Pro
Associated RC8B FT
tromoly is offline   Reply With Quote
