Brake tightness
How tight do you guys run your brakes,meaning should the 2 plates on each side be tight (losi 2.0)front and back.Or should they be loose just slightly.Is this more of a personel preference so when you let off throttle it will slow quicker.Say for a turn with less drift(tighter) or will this affect the strain on your motor,causing it to run hotter and burn more fuel.Just wondering what you prefer,thanks in advance.
I set them up so there is movement between the pads and disc. Say about 1mm ish. Then set the radio up and set the linkages/servo set-up so that i only have to touch the brake a little (on the radio) a little bit and it starts to 'bind'. Don't like drag brake as it messes with the car in flight..
Originally Posted by The fisherman
(Post 7154933)
To set them up, I take out the center diff, tighten the pads until I can capture the disc. Then back off slightly until the disc just falls out. Done. This allows braking to start when you barely breathe on the trigger, then I adjust how much pressure I want with the EPA. |
Thanks for your input guys.I think i had them too tight mainly in the back now when i'm off throttle it rolls a little better,before it would almost come to a halt,they sure don't give you much room to get to that back top nut.All the diffs are my next project after the 4 shoe clutch goes in.But the car seems good enough to race this sunday for now.You guys are great,I don't know what i would do without this site.
(Post 7154933)
