Old 03-17-2010, 10:41 PM   #1
Trader Rating: 20 (100%+)
Default Do dents & dings hurt ur pipes performance?
I have a few pipes that have lil dings in them n I was wondering if it will change a pipe dramatically. My 2013 has a lil bit of a flat oval curve to the bottom of it and I wanna no if it will still work ok?
Matt Piva is offline   Reply With Quote
Old 03-18-2010, 04:07 AM   #2
I haven't seen the thread lately but it's easy. Fill it with water, plug it, put it in the freezer a few days and it'll pop right back in place.
The Working Man is offline   Reply With Quote
Old 03-18-2010, 07:22 AM   #3
Dano628's Avatar
anytime you dent a pipe it effects performance so the answer is yes . I have popped dents out of pipes by using the freezing method mentioned above .
Dano628 is offline   Reply With Quote
Old 03-18-2010, 07:31 AM   #4
houston's Avatar
Trader Rating: 91 (100%+)
Yes it does matt , if the bottom is flattened out then performance will definitely suffer . What happens is that it could crack the divergent cone and it plugs the reverberation (tuning) holes that are engineered into the pipe .
Be very careful with the 2013 and the freezer , that thing is thin and will pop out easily !! But if the underside of the pipe is flattened out the freezer trick will not save it .
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-18-2010, 08:10 AM   #5
scwrod's Avatar
Do not leave it in freezer for days. Just check it frequently and pull it out if dents pop out.
Or just buy a new pipe
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 03-18-2010, 08:42 AM   #6
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
hey brother from another mother! buy a new pipe cheap sk8!
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 03-18-2010, 08:43 AM   #7
I've seen motorcycle pipes blown out with a little air pressure and heat. This might work on a thin RC pipe??
Flipfly is offline   Reply With Quote
Old 03-18-2010, 08:45 AM   #8
+100000000000000000
geejay is offline   Reply With Quote
Old 03-18-2010, 09:45 AM   #9
Lol If it still works decent why not use it more right haha. Houston I think I'm gonna just use my new 2013 n use the beat up one for my beat up engines. I don't need my fms running cheap stuff.
