Old 03-16-2010, 07:49 PM   #1
mista.matrix's Avatar
Default my 2.0 t is coming need info on...?
I need info on diff oils & shock oils I plan on ripping it down & rebuilding it to race spec...ANY INFO WOULD HELP....also what upgrades would you do from the beginning if you could do it again...
mista.matrix is offline   Reply With Quote
Old 03-16-2010, 07:57 PM   #2
l3asher's Avatar
All the info you need can be found here.
8T 2.0
l3asher is offline   Reply With Quote
Old 03-16-2010, 09:45 PM   #3
Jerm13's Avatar
Trader Rating: 36 (100%+)
Good truck. You cant go wrong with the box setup. it is a very good all around setup for just about every track. You need to be a little more spacific about getting it race ready though. What kind of track, type of dirt ect. As far as upgrades go, the losi arm holders with the plastic inserts are really good. King Headz maks good ones too but they are not adjustable like the losi ones. Also, the alluminum front and rear braces along with the top plate will do good. the plastic ones flex too much for me. the chassis has a built in flex so all these things makes for a chewed up spur and clutch bell. also a quick remove motor mount is a good investment. After a couple of good runs, you need to rebuild the diffs. at this time the lightweight outdrives and lite spur gear will do good for acceleration. good luck.
Jerm13 is offline   Reply With Quote
Old 03-16-2010, 10:25 PM   #4
THANKS BUDS, i thank you for your time & not just giving me a 400+ page link....
Old 03-17-2010, 05:15 AM   #5
l3asher's Avatar
You really should at least skim through it, tons of information in it. I would stay away from AL braces, the chassis was made to flex. Must do's are check the shock ends, al servo saver top, and check all the screws and fluids. If you bought the RTR you will need to look into new servos, the stockers will not last long.
Old 03-17-2010, 01:00 PM   #6
Thanks again I bought the racer, so I should leave the plastic braces about thee servo brace your talking about the top plate...? Right...?
5280 Raceway - Colorado On Road RC Club (CORRC) SlamMan Colorado Racing 21404 05-01-2017 07:55 PM
XERUN V2.0 Brushless ESC discussion thread. cyanyde Electric On-Road 1241 08-23-2014 08:57 PM
T-Bang Hobby Technology - Vancouver, Canada BigDaddyT Team and Company Discussions 577 08-15-2012 12:21 AM
Tekin Vegas 2.0 Setup and Support Randy_Pike Electric Off-Road 1713 12-06-2011 04:31 PM
