Old 03-17-2010, 06:19 PM   #16
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Originally Posted by dreaux View Post
two really small screwdrivers.
started out with a screw driver and needle nose pliers
Spend the $15. You'll be glad you did.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 03-17-2010, 06:40 PM   #17
After just putting in a new steering servo,I can see why these tools are made.I' get the tool before i build the 4 shoe clutch.Can some one tell me why after i put the new servo in that when i turn right it turns left and when i turn left it turns right I hope some one will tell me i can just switch this around the right way(is there a way to do this on the radio)i'm almost positive it's in the correct way.Please help i'm such a newb(......)insert other words here.Thanks guys.
The fisherman is offline   Reply With Quote
Old 03-17-2010, 06:49 PM   #18
What radio do you use? If it has a screen, you should be able to go through the menu to find a "reverse" or "servo reverse" feature. Go to the steering setting and reverse it(or if it is already reversed, switch it back to normal). If it is an analog radio without a screen, there should be an external switch somewhere with the same function. If you have the manual to the radio I'm sure the process is explained somewhere in there.
-Koby Kubrin-
Old 03-17-2010, 06:59 PM   #19
Red face
Jammin,
I think i do remember seeing that I'll go try that now,it's a spectrumDX3s i think that would be great after going through all that,I will dig out the manual.
Old 03-17-2010, 07:08 PM   #20
Jammin,
If it's the same as my DX3R which it should be, it will have a reverse section on the main menu.
-Koby Kubrin-
Old 03-17-2010, 07:27 PM   #21
Thumbs up
Jammin ,
That was the ticket thank god for that reverse button,now all i have to do tomorrow is rebuild the center diff hopefully.Thanks again.
Clutch shoe tool? bjr48 Nitro Off-Road 27 12-05-2008 08:00 AM
Purpose of the clutch shoe tool? karter15 Nitro Off-Road 13 12-03-2008 07:04 PM
Clutch spring tool kahuna2793 Electric Off-Road 6 04-29-2006 06:12 PM
