Old 03-17-2010, 07:00 PM   #16
mikesd1980's Avatar
Trader Rating: 66 (100%+)
Originally Posted by The fisherman View Post
I will try that mike when i get home,guess i never really noticed that it was loose and i got worried and tightened it a bit,when i started to adjust it to make it leaner the whole assembly turned and i just never seen it that loose.I'm going to mess with it when i get done work all night if i have to,also talked to the guy at the hobby shop and he told me the RTR losi's diff's come packed with grease not oil,so it probly needs to be done anyway.It's going to be a long night.
If the whole brass piece is moving than use some needle nose pliers to tighting it down on the outside where it looks like a hex. That will tighting that. If you talking about the inside where the the flat head go than turn that to the left till it about flush. That should be rich enough to keep it running than tune from there.
Mike Diggs
Agama USA buggy
Agama USA Ebuggy - Airtronics M12
Agama A8T Truggy - Hobbyprousa -NemoRacing
"Our perception and attitude toward any situation will determine the outcome"
mikesd1980 is offline   Reply With Quote
Old 03-17-2010, 07:04 PM   #17
Stubbs's Avatar
Trader Rating: 57 (100%+)
Originally Posted by neobart View Post
I agree with what you said Stubbs, but you go the pipes backwards. RE11 is the 2050 clone.
You're absolutely right....I always get those two backwards. I edited my post.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 03-17-2010, 07:34 PM   #18
Smile
Mike that was the problem the brass was loose,i tightened it and then started tuning,it was actually too rich,leaned it a little and a small throttle adjustment and now it's almost there.Thanks again.
The fisherman is offline   Reply With Quote
Florida Local Buy/Sell/Trade TimPotter Florida Racing 5441 08-15-2017 01:11 AM
F.s. Bunch of stuff ! Tools, chargers, oils, batteries ! Jamie22 R/C Items: For Sale/Trade 20 09-10-2009 07:51 AM
Why are so many leaving the hobby? olhipster1 Electric On-Road 285 09-11-2008 09:53 AM
