Old 03-17-2010, 02:19 PM   #31
Stanton's Avatar
Originally Posted by houston View Post
Thanks for posting that mike !!
Ends some confusion that was going on here
These engines are so simple yet so complex aren't they ?
I'm going to cut an old case, leave the bearings and see if the piston and rod balance with the couterweight. Is it that simple?
Horizon Hobby/Spektrum/Byrons/TLR/Houstons Engine Service
Stanton is offline   Reply With Quote
Old 03-17-2010, 04:16 PM   #32
DANE_TRAIN's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Racecrafter View Post
pdmustgt, I mean no disrespect. But I have to ask a question. Do you balance a Top Fuel engine the same way you do one that burns Methanol or Gasoline?
Haha, I'll answer that.
It's a trick question, because a "top fuel" engine does not run on Methanol or Gasoline. Not to mention, I have never herd of anyone having to re-balance an engine due to changing fuel.
Should we begin a new thread in the "chit chat" section so we can further debate 1:1 engines....?lol
Pro4mance Hobbies
DANE_TRAIN is offline   Reply With Quote
Old 03-17-2010, 04:34 PM   #33
Actually the balancing process is the same. What fuel you run doens't have an effect on the balance of a crankshaft and its rociprocating assembly.
I have balanced all of the above.
but balancing and porting these little engines are two different topics. I'm sure when these engines are designed they take a lot of care making sure the crank and rods are balanced because at more than 30k they will shake the heck outta themselves if outta balance and bearings wouldn't last long.
one8updragracer is offline   Reply With Quote
Old 03-17-2010, 10:40 PM   #34
I'm guessing we don't need them counter weights on the crank (key word counterweight) just cut them off ...Yes these are very simple engines just some are over thinking them.
Answer the 1st question they do a over balance for very high rpm engines. But not every builder agrees with this because cause imbalance at certain rpm ranges
pdmustgt is offline   Reply With Quote
Old 03-18-2010, 05:50 AM   #35
Suspended
Trader Rating: 41 (100%+)
Balance is balance. How can it be balanced at 30,000 RPM, but not at 18,000?
Puppies! Flowers <3
Cadimman is offline   Reply With Quote
Old 03-18-2010, 06:32 AM   #36
Roelof's Avatar
Send a message via ICQ to Roelof
Resonance.... depending the weight you will get a resonance at a certain rpm, you want that in a range the engine does not stay much time on that rpm. In resonance you could damage the whole engine.
Originally Posted by JonnyW View Post
I have a AxeRossi crank that has 2 tungsten? plugs right of center. And I have a Nova P5? crank that is drilled just left of center. Both cranks are identical in dimentions. I am actually running the P5 in the Axerossi(broke a damn screw off in the end) Why the different methods? I understand the flywheel adds mass but so does the crank. Look at MX bikes they have vitually no flywheel. In fact if run run in enduros with a MX bike most will add a heavy flywheel to smooth power and keep from stalling. More tractor like toque is what is desired. Im not trying to confront anyone I'm just asking.
Drilling holes is simple and cheaper but it will enlargen the crankcase volume and that will loose performance. From IDM (made by Novarossi) I have seen full round shaped crankshafts. A low crankcase volume will give more pressure to pump up the mixture faster to the combustion chamber what will give more bottom power.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 03-18-2010, 08:17 AM   #37
Since its a single cylinder, and you cannot balance it to the fullest, what you want is to get the resonance at least out of the operating range, and definitely out of the natural frequency of the engine - which shouldn't be a problem considering that we do not see many engines exploding to pieces.
But that does not mean that there are "many balancing points" there's only one, for all rpm ranges, its just that it gets more and more critical the wider or higher the rpm range is, since basically all engines will be at idle at a certain time.
That's the reason you see it more in on-road engines that operate from idle to 40-45k and not in off-road ones that mostly do idle to 30k-35k. It's less critical for the smaller ranges.
x
maxflo777 is offline   Reply With Quote
Old 03-18-2010, 08:23 AM   #38
Maximo's Avatar
even changing fuel % and tune will alter the resonance...so even if you have the engine dialed in perfectly ( using a vibrex type machine ) the parameters will change as soon as you start altering the explosion on top of the piston....EB Mods is the only modder I know who owns the proper equipment for balancing these engines.....
Maximo is offline   Reply With Quote
Old 03-18-2010, 08:50 AM   #39
Racecrafter's Avatar
Trader Rating: 25 (96%+)
So you don't compensate your counter weights for nitro?
Up to 40% I can see. Something like an exhibition car. But for TF or anything upward of 80%+?
You have to compensate for the twist or you'll eat the mains out of the block.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 03-18-2010, 09:01 AM   #40
Way off subject but on BIG power like TF, those engines only need to last 5 seconds at WOT. With that ammount of power on all the working parts a little twist is inevitable. By the time the crankshaft in and engine twists enough to throw the balance off...its already too late, and something bad already happened.
Old 03-18-2010, 09:13 AM   #41
houston's Avatar
Trader Rating: 91 (100%+)
you boys are just getting silly now
these are not top fuel drag race engines
if we are talking about 1/8th nitro off road .21 or .28 engines then lets do so
there is a vast wealth of knowledge out there to be had simply by using your favorite search engine on your pc or mobile device or however you choose to do it .
as far as crankshaft "balancing" goes, its pretty broad as far as the generalization of "balancing" goes , if you actually want to understand the mechanics of why it needs to be balanced ( or imbalanced ) then it takes a little greater deal of knowledge retention and being able to understand the physics of it all . why a crank has a "counterweight" and what it does to effect the firing program of the combustion chamber and all kinds of BS that most people dont even need to know
my 2 cents
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-18-2010, 09:18 AM   #42
M.Gustafson's Avatar
http://www.modelenginenews.org/etw/etw_bal/p2.html
Good info.
Mike Gustafson
Medina, TN.
731-414-7177
M.Gustafson is offline   Reply With Quote
Old 03-18-2010, 09:33 AM   #43
houston's Avatar
Originally Posted by M.Gustafson View Post
principles are correct but it doesnt take into account the force from the firing of the cylinder nor the amount of force (inertia) it takes to get the piston/rod assembly back into the firing chamber.
overall a most excellent understanding of crank balncing is to be had out of that article , especially for being published in 1951 holy smokes !!
great find!!!
Old 03-18-2010, 09:43 AM   #44
Very true on the firing. Unless the throttle is set to a constant RPM there is no TRUE balance in a single cylinder engine. The force you mention is changing with every change in RPM. Different Force = no TRUE balance.
Thanks by the way. Been around these engines and this conversation for way too many years. And NO not since 51.. lmao
Mike Gustafson
Medina, TN.
731-414-7177
Old 03-18-2010, 12:46 PM   #45
Roelof's Avatar
At the end you want a lower weight for all internals, the lower the weight the less you have to balance.
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
Crankshaft Balance dameetz Onroad Nitro Engine Zone 59 03-16-2005 04:30 AM
NSR crankshaft nonconcentric boom Onroad Nitro Engine Zone 9 06-04-2004 10:18 PM
