Old 03-15-2010, 07:35 PM   #1
chewie219's Avatar
Default starter box problems
Ok, so I was being a friend and was letting someone borrow my starter box. It seems that it was under a lot of "stress" and the wires that go to the motor came loose. The motor was really hot and then the wires came unsoldered.
1. Is the motor shot?
2. How do I get the motor apart to resolder?
3. How do I get the rubber wheel off?
It is an OFNA True Start, starter box. Thanks for the help once again.
Chewie219 - OFNA 9.5 Buggy, RC10Gt w/OS .15
chewie219 is offline   Reply With Quote
Old 03-15-2010, 07:54 PM   #2
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Well , there are several True Start boxes . But on any there should be tabs on the motor to solder the wires back on . Most likely the motor is ok as the wires prob came off due to a bad solder joint and came off when shouldn`t . Solder the wires and test it out .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 03-16-2010, 09:09 AM   #3
chewie219's Avatar
The problem is that the wires go inside the motor case. I can not get inside the motor to solder them back on. Tried to take the rubber wheel off with no such luck. It is an OFNA True Start box the blue one. I am in a panic because I can't start any of my cars without it.
Old 03-16-2010, 09:29 AM   #4
fatdaddy's Avatar
those motor are sealed i believe. they are not meant to be opened.
if they got hot enough to unsolder themselfs, theres a really good chance they are toast.
is this the starter box with the one giant motor, or two small motors?
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 03-16-2010, 09:33 AM   #5
Briguy's Avatar
You will need a new motor .
To take the wheel off , you need to hold the wheel and remove the nut , then tap the wheel off , it is a taper fit so will take a bit to get off .
Royal R/C & Hobby
Old 03-16-2010, 09:38 AM   #6
chewie219's Avatar
It is 1 giant motor. Whenever I turn the nut to try and take off the bolt that it is on just spins. That really sucks if I have to replace the motor. Any idea where I can get just the motor?
Old 03-16-2010, 09:40 AM   #7
Briguy's Avatar
Nitrohouse - http://www.nitrohouse.com/catalog/pr...ducts_id=14263
If the shaft is spinning you will need to pull back really hard on the wheel while holding it .
Royal R/C & Hobby
Old 03-16-2010, 10:28 AM   #8
The motor may be ok. You just have to solder the wires back and test it. Just remove the nut that holds the rubber wheel. There are nuts on the front motor plate. (behind the rubber wheel) Remove the nuts and you can disassemble the motor.
D Starks is offline   Reply With Quote
Old 03-16-2010, 11:23 AM   #9
fatdaddy's Avatar
oh wow. i never knew that. ive always wanted to run 12ga. wire right to the motor, but i assumed it was sealed. so i ran it as close to the motor as i could
i need to look into this
Old 03-16-2010, 11:55 AM   #10
DarthRacer's Avatar
This is probably a good place to ask this.
Does anyone know how many cells are in the lead acid batteries for these starter boxes? My charger has the capability to charge them but I want to make sure I set it up correctly.
DarthRacer is offline   Reply With Quote
Old 03-16-2010, 05:53 PM   #11
chewie219's Avatar
Ok. So I got the engine apart. Awesome. Now I have no idea which wire goes where? Any ideas? Where does the red go? Where does the black go?
Old 03-16-2010, 06:00 PM   #12
hook it up to the battery and test the poles til they are right. That is what i would do and i am an electrician Really might not be a right or wrong way. but it might affect the direction. but i don't know.
btw, which one is better the one with the big motor or the one with 2 smaller motors?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 03-17-2010, 06:10 AM   #13
chewie219's Avatar
I figure I would have to do a trial and error just didn't know. I have always heard that the big single motor is better.
Old 03-18-2010, 01:08 PM   #14
chewie219's Avatar
Update: I got the motor apart and soldered back together by just guessing. I guessed wrong. I just reversed the wires and it is perfect once again. Thanks for all of the help.
Old 03-18-2010, 02:27 PM   #15
fatdaddy's Avatar
nice!! those giant motors really are bulletproof.
MBX5R with OFNA starter box problems.. pracy Nitro Off-Road 13 05-12-2008 03:55 PM
starter box problems TC3 BUDRACER1 Rookie Zone 7 09-09-2003 01:15 PM
