Old 03-14-2010, 06:24 PM   #1
Default clutch breaking springs
my clutch had a hanging shoe twice today (dynamite max life, 1.0 springs). and each time the clutch spring had broke on the part that sits in the groove on the flywheel nut. i replaced the spring and it happened again. At the end of the day i was breaking down the clutch to clean the engine and i noticed the shoes were not sitting on the flywheel properly and the shoes were a bit loose on the flywheel. the shoes have a few gallons on them (they do last forever), but they still have a couple gallons left. I think the bottom of the shoe where it spaces it of the flywheel is worn off. It is literally sitting flat on the flywheel.
I could replace the shoes and flywheel, but i don't see a reason for it unless i have too. the pins on the flywheel look a little worn but not near as much as some other flywheels i have.
anyone know what's going on?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 03-14-2010, 06:33 PM   #2
J.Sears's Avatar
What kind of springs are they? If there mugen springs I have seen alot of these springs break try a different spring. JMO
J.Sears is offline   Reply With Quote
Old 03-14-2010, 06:42 PM   #3
well i have had this car for almost 2 years and have never had this happen. besides, what spring would you suggest? i have tried racers edge springs, but those springs are wwaaayyy to tight.
Mugen
Old 03-14-2010, 06:49 PM   #4
jmaxey51's Avatar
i had the same problem as you a few times, i run the same shoes. i broke 2 sets of mugen springs (1.0) and 1 set of ofna gold springs (1.1). but i have used kyosho 1.0 everytime except the those three times i ran those others so i say use kyosho springs.
jmaxey51 is offline   Reply With Quote
Old 03-14-2010, 07:01 PM   #5
it weird because i am breaking in a new engine and i am not being hard on the throtle at all. Not even bliping.
btw, i was putting on my flywheel last night and my lug wrench striped out. I had a deep socket and i tried to get on the flywheel nut and it didn't fit inside the pins very well and it might have bent them, but i can't tell.
Mugen
Old 03-14-2010, 07:04 PM   #6
halfman's Avatar
Do your springs stick out of the clutch shoes when they are on the flywheel? Could it possibly be your clutch bell
Sponsors: Xray, RC America, Novarossi, Indy RC World Paint by RJ, Vp Racing Fuels, SPD Mods, Avid Bearings, Desoto Racing, Speed monkey Batteries
halfman is offline   Reply With Quote
Old 03-14-2010, 07:16 PM   #7
1. NO
2. possibly. The clutch is pretty old (racers edge vented tri nitrate). It's possible that the shoes have worn out the clutch bell to the point where the shoes have to go out further and stressing the springs. But the clutch bell would have to be worn to just about nothing. And i have never even heard of that happening.
Mugen
Old 03-14-2010, 07:18 PM   #8
J.Sears's Avatar
It very well could be the clutch bell check to see if it has a grove on the inside of it. If it does take a sanding drum and smooth it out.
Old 03-14-2010, 07:58 PM   #9
yeah, just checked before you suggested it. yup. 2 big grooves. There is a rail in the middle.
but why would that break my spings?
Mugen
Old 03-14-2010, 08:33 PM   #10
Jaz240's Avatar
Trader Rating: 52 (100%+)
Your springs will get caught in the grooves and snap them. I would suggest you change your bell and your clutch shoes. Your springs should not ever touch the bell. If they do it means you need new shoes
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 03-14-2010, 08:51 PM   #11
vince7870's Avatar
Trader Rating: 15 (100%+)
you can use the kyosho clutch springs on mugen. they work great and is what i was using last year when the mugen ones were breaking
Lead, Follow or get out of my way!
vince7870 is offline   Reply With Quote
Old 03-14-2010, 08:56 PM   #12
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Cough... FIORONI... Cough... Cough...
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 03-14-2010, 09:17 PM   #13
CaribbeanPirate's Avatar
Send a message via AIM to CaribbeanPirate Send a message via MSN to CaribbeanPirate
Have you tried their new "Vario" Self Ventilating clutch?!?! I think this is going to be my next clutch system!
CaribbeanPirate is offline   Reply With Quote
Old 03-14-2010, 09:20 PM   #14
Na, I run the turbo sliding clutches. I wanted to get away from aluminum shoe clutches. The sliding clutch is just a much better design IMO.
-Koby Kubrin-
Impulse-r/c Clutch Shoe Review Steebo Nitro Off-Road 73 03-31-2010 09:08 PM
Clutch shoe life AsSc8 Nitro Off-Road 15 09-23-2009 08:25 AM
Need clutch advice bjr48 Nitro Off-Road 20 12-08-2008 03:37 PM
