Old 03-14-2010, 04:36 PM   #1
novak man's Avatar
Trader Rating: 29 (100%+)
Default losi 1.0 parts work on the 2.0 buggy?????
hey guys, got a quick question for yall, all right so i got a losi 1.0 buggy, and was wandering if a the parts from it will work on the losi 2.0 buggy?
novak man is offline   Reply With Quote
Old 03-14-2010, 08:28 PM   #2
CaribbeanPirate's Avatar
Send a message via AIM to CaribbeanPirate Send a message via MSN to CaribbeanPirate
They have a lot of parts in common, not all of course... download the manuals from http://www.losi.com/Support/Manuals_PartsExplosion.aspx and do a cross check for the ones you're interested in
CaribbeanPirate is offline   Reply With Quote
Old 03-14-2010, 09:26 PM   #3
novak man's Avatar
thanks for the help
Old 03-14-2010, 10:07 PM   #4
8&stuff's Avatar
Trader Rating: 55 (100%+)
As far as i can see pretty much everything will work from one to the other xept for a few major differences. Such as the 2.0 chassis unless you have the longer rear 2.0 driveshaft, the servo saver arm from the updated 2.0(saver) is actually the 1.0 arm although the original 2.0 arm is not compatable with 1.0, and the rear diff bearing inserts are larger. Everything else for the most part(as far as i can see) is compatible with no modding such as the 1.0 linkage ends into the 2.0 rear hubs as well as front spindles, the 1.0 spindles&rear hubs use a 6.8mm ball and the 2.0 uses a 5mm ball so it takes a little forcing and vice versa. I at different times have used 1.0 parts on my then new 2.0. I currently run 100%2.0 parts
Mark Buecker
8&stuff is offline   Reply With Quote
Old 03-14-2010, 11:03 PM   #5
novak man's Avatar
thanks for the info that was very helpful, so basically all i need is the rear 2.0 diff case and the bearing inserts for it and i should be good
Old 03-14-2010, 11:14 PM   #6
8&stuff's Avatar
Yes. I would also possibly look into aluminum rear diff inserts. The plastic inserts do not last very long and eventually need replaced. Although this is not totally needed, just keep an eye on them every couple gallons if you use the plastic.
Old 03-14-2010, 11:21 PM   #7
novak man's Avatar
all right thanks for all your help
Old 03-15-2010, 02:24 AM   #8
dishsoap's Avatar
I believe the rear outer hinge pins are different as well. On the 2.0 the thickness of the pin is bigger than the 1.0.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
Losi 2.0....Losi 1.0 What parts are interchangeable? robbdny Nitro Off-Road 48 04-25-2014 05:05 AM
Losi 2.0 Buggy BCE Starter box 350s 8800s UltegraSTI R/C Items: For Sale/Trade 8 10-26-2009 06:31 PM
