Old 11-04-2004, 08:20 AM   #1426
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
I did not know that Casper.....thank you for that!
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 11-04-2004, 10:13 AM   #1427
Casper
Thanks for that tip. Taper pins seem to be really great to a point and then they let go. I imagine that positive camber also lets more of the middle bars contact the ground instead of just the inside pins.
Another question-
I need to replace my throttle servo and would rather not purchase one of the pricey airtronics 94357s. Do you have any recommendations as to the best torque/speed combo?
toddzhere2 is offline   Reply With Quote
Old 11-04-2004, 12:24 PM   #1428
Casper's Avatar
Trader Rating: 33 (100%+)
Another thing on the pos camber is that I noticed that tire wear was decreased.
For trottle servo you cannot bet better then a 94737. It is a great throttle servo at .12sec and 70 in-oz of torque @ 6V. The Futaba 9202 is what I am running .21sec at 96 in-oz @6V. Both servo's are around $70. Speed and torque are not as important in a trottle servo and you do not need very much torque to stop a stadium truck.
I would not worry about speed but get torque in the 70 in-oz or greater range.
Casper is offline   Reply With Quote
Old 11-04-2004, 01:40 PM   #1429
Brian Miskolczi's Avatar
Trader Rating: 154 (100%+)
Aaron or Casper. I run on a very high bite indoor track, we run slicks, the clay is very tacky and the track is very smooth with some medium size jumps. I have a good setup now, but i was wondering if the increased positive camber, and a few other adjustments could help to give the truck a more aggressive, loose but controlable feel to get faster lap times. Thanks for any help you can give me, Brian Miskolczi.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 11-04-2004, 02:02 PM   #1430
Casper's Avatar
It does not cost anything to try this. I have heard lots of antisquat work well on those types of tracks but this can be hard with the GEN II tranny. You need to shave the hinge pins so they do not rub on the outdrives to get more then 3-4 deg of antisquat. Try the camber change and see how you like it. All else fails you make a couple turns and put the camber back!
Old 11-04-2004, 02:28 PM   #1431
AARON, I DIDN'T REALIZE YOU HAD OBTAINED SUCH A STATUS, YOUR VERY OWN THREAD. NICE TO SEE YOU GIVING SO MUCH GOOD ADVICE. ANY PLANS ON RUNNING THE REGION 12 RACE?
CASPER, WHAT ABOUT YOU AND RYAN ANY PLANS FOR REGION 12?
M LANE is offline   Reply With Quote
Old 11-04-2004, 02:32 PM   #1432
Casper's Avatar
Ryan will be in Vegas. I will be on business travel all next week so I think I will have to pass. I would really like to race it but I do not think I will be in town for it. Ryan and I are going to Titus on Sat to race to practice for the JBRL.
Old 11-04-2004, 02:33 PM   #1433
xyzracer's Avatar
For throttle in my gas truck I run a jr 590m servo. Its metal gear, 85 oz and .15 tranit time and about $40 bucks. Can't beat it in my book. Also, havent had any problems so far either.
xyzracer is offline   Reply With Quote
Old 11-04-2004, 03:42 PM   #1434
I have a forty minute main comming up, I currently run a 1100 vennom receivor pack, will it last??
TIA
Dave Mac
D Mac is offline   Reply With Quote
Old 11-04-2004, 03:47 PM   #1435
Casper's Avatar
No problem. Just make sure it is fully charged before your main.
Old 11-04-2004, 04:52 PM   #1436
Sofast-NT's Avatar
Aaron,How Is the center of gravity on the ad2?
Sofast-NT is offline   Reply With Quote
Old 11-04-2004, 05:22 PM   #1437
Aaron Waldron's Avatar
No reason to run a spring AND fuel tubing. When the spring is very close to being compressed it is already very stiff and acting like fuel tubing; adding tubing in there just takes up adjustment room.
Todd - Casper's post was dead-on. Adding washers will smooth out steering and help keep the front end flatter (less camber change). Removing washers will give you more aggressive steering and the front end will feel softer (the tire will also have more camber change). There really isn't much effect with respect to being on- or off-power.
Positive camber in the rear has the same effect of making the camber link longer; it keeps the rear end flatter when cornering, which puts more pressure on the tire and creates more sidebite. The inside (inweighted) tire now has more rubber on the ground and can offer more traction.
SoFast-NT - The new truck is really good. Everything sits very low.
D Mac - 45 minutes should be no problem.
Lane - Shane and Troy suckered me into doing this..haha. I'm not sure if we're going to Titus; we have the Gas Regionals left still this year.
Brian - In addition to the extra anti-squat, here's a few other things to try:
Move your rear hubs forward. Run the outside hole on the front bulkhead with no washers to give your car the most steering. (You may also want to dial in 1/2 or 1 degree of toe-out to make the truck even more aggressive).
When I want my cars to be aggressive, I want the rear end to follow the front end instead of sliding around the corner. Positive rear camber won't really make the truck want to swing around corners but you should be able to rail around them quickly. Try short rear arms if you want less overall side-bite.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 11-04-2004, 06:33 PM   #1438
beetlebz's Avatar
Send a message via AIM to beetlebz
actually, at rest, the brake spring is partially compressed. i dont use the full range of braking, just a little for slowing down, and then for slamming on the brakes. the tubing makes the throw from soft braking to a full lockup a bit shorter. but actually, i put on a whole new linkage assembly tonight and im going to run it stock to see if i like it.
its not a huge difference, but ive found it does make snapping the brakes a bit easier. maybe its just me.
aaron, i got a good question for you. when people talk about making thier suspensions more "progressive", what does that mean? how does laying down or standing up your shock positions affect the handling of the truck?
beetlebz is offline   Reply With Quote
Old 11-04-2004, 07:02 PM   #1439
When referring to a more progressive suspension, it means that the shock feels stiffer as the arm travels through its range of motion.
Laying the shock down will make it more progressive, while standing it up will make it more linear.
www.liverc.com
Old 11-04-2004, 08:50 PM   #1440
That sounds pretty dialed! Why doesn't everybody run posative camber then?
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
