Old 10-28-2004, 01:06 PM   #1321
Sofast-NT's Avatar
Thanks AW
Sofast-NT is offline   Reply With Quote
Old 10-28-2004, 01:10 PM   #1322
AW
On this carb, for the siro, isnt their supposed to ba a gasket on the neck of the carb, that attaches to the engine? mine didnt come with one.
Dave MAc
D Mac is offline   Reply With Quote
Old 10-28-2004, 01:15 PM   #1323
Sofast-NT's Avatar
No,but theres supposed to be one on the backplate.
Old 10-28-2004, 01:33 PM   #1324
Sofast thanks
I guess I better take out the one I put on then lol
What about the air filter, my dynamite I use on my os carbs wont fit, what do you guys use?
THanks
Dave mac
Old 10-28-2004, 01:34 PM   #1325
Casper's Avatar
Trader Rating: 33 (100%+)
Use high temp RTV to seal the carb to the case and it is also a good idea to put some around the threads of the high speed needle to prevent leaks. Do not go overboard with the RTV. A thin coat is all it takes.
You hobby shop may have some of this stuff in a small container or you can just go to an automotive store and get a "life time" supply in a tube.
Casper is offline   Reply With Quote
Old 10-28-2004, 01:48 PM   #1326
Casper's Avatar
Most Italian engines use 11mm filter attachment. The OS is 10mm. You should be able to press on the Losi or Associated air filter. This is what I am using on my OS carb an my Nova Rossi carb. It fits both although I do not interchange them. The Nova Rossi "stretched" the one I use on that and it will not fit snug on the OS anymore. I also add a zip tie to the air filter to help it stay in place.
Old 10-28-2004, 06:22 PM   #1327
Which header do you guys like for this Drake engine?? My associated header is so much smaller whear the openings meet, Im not sure I can Dremel that much out to make them equal.
And what are good setting on the carb, Ihave found about 2 on top and bottom a good rich setting for most .12 I have had, does this hod true for the Siro
Dvae Mac
PS no way is my dynamite filter fitting, So AW what do you and Drake use?
Old 10-28-2004, 07:22 PM   #1328
Aaron Waldron's Avatar
I was using the OFNA 1/10th scale filter..but I switched back to the stock Losi filter. BIIIIIIG power increase!
The Sirio engine should be tuned in the same manner as any other .12.
Casper - You're dialed
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 10-28-2004, 07:35 PM   #1329
warpig's Avatar
strange...
warpig is offline   Reply With Quote
Old 10-28-2004, 07:58 PM   #1330
Casper's Avatar
I am bored at work so I am picking up some slack while you are in school trying to fill that brain of yours with all that "useful" knowledge they throw at you in college!
What is so strange warpig?
Old 10-28-2004, 08:03 PM   #1331
warpig's Avatar
oh.. the air filter thing.. I've never had a change in performance changine air filter types.. assemblies.. etc.. the ofna must restrict a lot
Old 10-28-2004, 08:25 PM   #1332
Casper's Avatar
It is just like going from a clean filter to a dirty one. You may even need to retune the engine since there is more air now! It will produce more power if you can get more air in also which is always an benefit to keeping that filter nice and clean!!!!
Old 10-28-2004, 09:10 PM   #1333
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
When you say "Losi Stock filter" does that mean the one in the kit?....the brass and paper one? or something else?
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 10-28-2004, 09:21 PM   #1334
Default 19 turn spec.
Aaron- I know you don't run spec class so this one's for Casper.
Casper-
I haven't run electric for about 10 years but the MF2 looks so great that I couldn't resist! Which 19turn spec works the best in your truck. What spring and brush setup makes the best power? How do you gear it for HRH.
Thanks!
toddzhere2 is offline   Reply With Quote
Old 10-28-2004, 09:38 PM   #1335
It's all about the Chameleon..hahaha
The Losi air filter that comes with the kits (brass and paper one), combined with the new pre-filter that will come with the AD2, is super dope. I'm not sure why there was so much more power, but I think it has to do with there being no elbow in between the filter and the carb, it's just a straight shot. Either way, it was a huge difference.
Casper - I didn't have class today..you were picking up my slack while I was picking up the slack at work today. I was there for two hours longer than I was supposed to be
www.liverc.com
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
