Old 10-18-2004, 05:42 PM   #1201
Default Drake 2
Aaron
Im sure you are still buried with AD2 questions. Sorry!
I noticed that the AD2 has a new beefed up rear pivot plate. Why didn't Losi make a new aluminum plate instead of the graphite one? I'm sure the truck has been tested with this new plate. Is there a need to run the trinity aluminum pivot ?
I also noticed that the truck is pictured with a pink spring. I know this spring is way too soft for the AD1. Has the rear suspension geometry been redesigned? If so, why the softer rear spring?
toddzhere2 is offline   Reply With Quote
Old 10-18-2004, 09:00 PM   #1202
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Aaron,
OK...scenario. You're practicing with you buggy and everything is feeling like 87-ish%. The back end is really planted and allows you to lay down the power safetly. It jumps and lands just fine. But you want a tad more mod corner steering. Is this a setup change or tire change? Currently you're running Red Tapers with standard foam in front and silver tapers with standard foam in rear.
What do you do?......what, do, you, do!?
Thanks!
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 10-18-2004, 10:24 PM   #1203
Send a message via AIM to waterblast02
Aaron, do you know why HobbyPeople doesnt carry Losi and Schumacher? And also how come they have decided not to hold anymore parking lot races in Escondido? Is it because of the lack of space or the bad asphalt?
waterblast02 is offline   Reply With Quote
Old 10-18-2004, 10:57 PM   #1204
TCR
I buy arron Lunch and ask him to drive my car for me in the main =)
Originally posted by mafiaracers
Aaron,
Thanks!
TCR is offline   Reply With Quote
Old 10-18-2004, 11:00 PM   #1205
TCR
They don't buy from Horizon? My two cents is they may eventually only sell XTM, they used to sell losi, until losi started to really get big and they realized, Losi is just too high quality for them to carry =) kidding
Old 10-18-2004, 11:08 PM   #1206
Heh...Hope they never decide to carry only XTM. The one truck we got from XTM sucked and hasnt been driven for a year or so now since just too many problems with it. Had to get it fixed the first time we took it out due to tranny problems.
Old 10-18-2004, 11:12 PM   #1207
TCR
they make XTM if you didn't know, a lot more money in it for them to sell XTM, take you for exmple, they sell you a crappy truck, you buy lots of parts, they make lots of money, not as much money in other manufacturers for them.
Old 10-19-2004, 12:03 AM   #1208
Aaron Waldron's Avatar
mafia - I don't know what people get when they reach 1000..
I hit that total pretty quick!
toddzhere - I am running Sirio engines..Adam Drake does a small port tear drop towards the exhaust side of the transfer ports on all of my engines.
The new pivot block is plenty strong. The point was to get the strength back without the added weight.
I'm not sure for the reason of having pink springs on the truck in the picture.
mafia - TCR has a pretty dialed idea..haha.
I might add a tad bit of drag brake, but I'd probably try another 1/2 degree of negative camber. Personally, I don't change setups when it comes to little stuff like that, I'd rather make adjustments with my hands (while I'm driving ).
Hobby People is owned by Global Hobby Distributors, which distributes all of the product they sell through the Hobby People stores. Losi is owned by Horizon, who refuses to sell Losi parts to Global for various reasons. Global also does not import Schumacher stuff.
As long as Global continues to distribute other brands' products, they will sell them in addition to XTM. To ignore such a large chunk of the market by only carrying XTM would be a poor decision.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 10-19-2004, 12:21 AM   #1209
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Aaron,
I see that you broke the 1000 barrier....too bad you're a moderator, now you don't get a cool name or title. What title do I get when I hit 1000?
Aaron - Hi.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-19-2004, 12:26 AM   #1210
Hahaha..*sigh*
What's up Troy?
www.liverc.com
Old 10-19-2004, 12:29 AM   #1211
RCTech Member #2
TSR6's Avatar
Originally posted by Aaron Waldron
Hahaha..*sigh*
What's up Troy?
Not much, Just chillin, playin with my new cell phone, helpin you out on your thread.
You?
Troy
RCTech Member #2
Old 10-19-2004, 09:15 AM   #1212
rod_b's Avatar
Send a message via AIM to rod_b
Aaron - do you use the GTX? I've heard it's a great ESC from the on-road guys but I was wondering if anyone is using it for offroad and if so, how they like it.
rod_b is offline   Reply With Quote
Old 10-19-2004, 09:43 AM   #1213
Trader Rating: 17 (100%+)
Aaron, back on page 60, you stated that the ratios for the MF1 and MF2 are 2.4:1 and 2.55:1 respectively.I could be wrong, but doesn't the manuals specify the MF1 to be 2.43:1 and the MF2 to be 2.53:1?? I was just wanting to verify these ratios because I have Final Drive Ratio charts figured at the 2.43 and 2.53 ratios.I would appreciate it if you could verify the ratios. Thanks.
rcdude69 is offline   Reply With Quote
Old 10-19-2004, 10:27 AM   #1214
Casper's Avatar
Trader Rating: 33 (100%+)
According to the MF2 manual on sheet ii the internal ratio of the tranny is 2.56:1.
Casper is offline   Reply With Quote
Old 10-19-2004, 02:26 PM   #1215
Sofast-NT's Avatar
Will my xxx-nt rims work on the AD2?
Sofast-NT is offline   Reply With Quote
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
