Old 10-17-2004, 03:58 PM   #1186
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Aaron,
alright, I went out for some practice today and made some very productive adjustments. In the rear....I went from 1-a to 2-a and rear traction shot up. Then also in the rear, I went from 25-56 to 32.5-55 and again, better traction. In the front, I'm still runnin' the 3-b link but didn't have time to try the 2-b. What is the 2-b gonna do for me? Also, how come no body ever runs the a-hole
(sorry had to do that) on the front caster block?
Thanks!
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 10-17-2004, 04:48 PM   #1187
Aaron Waldron's Avatar
Snikkari - The tranny for the old XXX-T is 2.4:1, while the generation II tranny is 2.55:1
18/86 will get you close to 11.13.
mafia - 2-A will smooth out steering and keep the front end flatter. I'm not sure the difference between changing the link on the caster block versus the bulkhead, but all desired changes can be made on the bulkhead, so I don't think anyone has found a reason to mess with the caster block.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 10-17-2004, 08:54 PM   #1188
beetlebz's Avatar
Send a message via AIM to beetlebz
karter, just send it back. ive fixed antenna wires before, and they are NEVER the same. maybe not drastically bad, but less range, more glitch prone, its never turned out well.
mafia, that crack (ouch no pun intended) left the way clear for so many horrible a-hole jokes. and due to my sensibilities, and distaste for being banned, ill keep them to myself lol
beetlebz is offline   Reply With Quote
Old 10-17-2004, 10:11 PM   #1189
Good choice.
www.liverc.com
Old 10-18-2004, 07:12 AM   #1190
My focus at the track yesterday was to work on the rear end of the car and get it situated to where I can lay the power down with more confidence that it would stick. But like I said, I just didn't have time to mess with the front end. Another adjustment I wanted to tinker with was my front shock location. The track layout is wierd, every jump is on a turn or leading into a turn so the car has to be planted right off the landing. Right now, when I downside a jump....right before the car settles at the bottom, the front end is grabbing and (more times than I'd like) swinging the car sideways.
I'm mounted inside on tower and middle on arm...with 27.5-57....and no limiter. Buuuuut...I was thinking of trying 30-57-.200" internal and mounting 2-inside. to try and take away the super grippieness. What do you think?
Thanks!
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 10-18-2004, 07:26 AM   #1191
Rysuleod's Avatar
Pro-line edge front truck tires
I bought some pro-line "The Edge" front truck tires and I realized that they don't really indicate which side is the inside of the tire and which is the outside.
Pro Line site
Here is a better picture than the Pro_line site.
[edit] I guess Tower Hobbies doesn't allow direct linking!
Let's try a link instead!
The Edge
Notice the different angles of the tread ribs on the bottom tire. The top half is more vertical, the bottom half is slanted toward the vertical ribs.
Extra info. I am currently using Losi 8 rib red fronts and we have plenty of steering on a hard packed indoor dirt off-road track. I thought I'd give these things a try just for fun but once the glue is set its set for good and I don't want to make a $27 mistake. Thanks guys!
Rysuleod is offline   Reply With Quote
Old 10-18-2004, 08:14 AM   #1192
Default Adam Drake 2
Aaron:
I can't wait to take a look at the New Drake. I understand that the transmission has been redesigned to allow rebuilding without removing the brake hardware. Great idea! Do you know yet what transmission parts have been redesigned? I have a spare transmission and another spare diff that I just put together. Will they work with the new truck? Has anything changed in the diffs? Also, should I start selling my tire collection or will the old front and rear tires still work on the new axles and hub carriers?
Thanks!
toddzhere2 is offline   Reply With Quote
Old 10-18-2004, 08:25 AM   #1193
mafia - I'd move out on the arm to make the front end more stable.
Rysuleod - We only run Edges on blown out tracks in an effort to take away steering. The V-shaped ridges are mounted on the outside.
todd - The old tranny will fit. The diff has a new thrust bearing but the old one will work.
I've been hearing about a conversion kit to use the old rims on the new truck, but I'm not sure of any details.
www.liverc.com
Old 10-18-2004, 08:37 AM   #1194
Davidka's Avatar
Trader Rating: 75 (100%+)
Hi Aaron, I am long time losi fan (had the 1st gen. JRX2) and I've noticed that the instruction manuals no longer have sugested gearing charts in them. Is there one available?
I'm interested in trying the dogbone/plastic universal setup too, is there a part# for a conversion kit?
You-Da'-Man.
BTW, you're a very eloquent writer. I hope you'll continue to contribute to websites/magazines like these.
Old 10-18-2004, 12:17 PM   #1195
Our resident rocket scientist, Casper, has a gearing chart on his website (at least he did the last time I looked at it). We'll see if he can post a link when he reads this.
The problem with providing gearing blanket gearing advice is the diversity of motors and tracks that we now race on..it's just tough.
Are you looking for BK2 dogbones? I'm not sure of any conversion kit, but I will get the part numbers for the individual parts when I get home from work tonight.
I love to write..I'm actually sitting in my journalism class right now.
www.liverc.com
Old 10-18-2004, 12:57 PM   #1196
Casper's Avatar
Trader Rating: 33 (100%+)
http://home.socal.rr.com/casper04/Gear_Chart.htm
Is the link to the chart page itself or you can go to
http://home.socal.rr.com/casper04 and click the infosheets to see the chart.
Gearing is for the original XXX tranny. I would gear one tooth down from all these recommendations for the Bk2 but the truck gearing still apply for the MF2 (did not change my personal gearing) I plan to update the chart soon for the GenII tranny.
Casper is online now   Reply With Quote
Old 10-18-2004, 01:23 PM   #1197
Sofast-NT's Avatar
Aaron will the Team Losi towers,arms & rims off my XXX-NT fit the AD2?THANKS
Sofast-NT is offline   Reply With Quote
Old 10-18-2004, 03:29 PM   #1198
Yes, but there is no point.
www.liverc.com
Old 10-18-2004, 03:38 PM   #1199
Aaron,
I see that you broke the 1000 barrier....too bad you're a moderator, now you don't get a cool name or title. What title do I get when I hit 1000?
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 10-18-2004, 03:44 PM   #1200
Default Which Motor
Aaron
Which motor are you running in your Drake? What modifications do you do to the sleeve?
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
