Old 10-04-2004, 05:23 PM   #1036
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
lean-out the bottom end and or open the carb at neutral to allow more air to enter so it idles higher. But I would bet that you need to lean-out the bottom.
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 10-04-2004, 06:00 PM   #1037
Evan's Avatar
what do i need to do if im not gettin gas from the tank like it is gettin enough gas for the first acceleration but then it doesn t get anymore. i took off the priming line from the exhaust because i was told that it is better is this part of it
Evan is offline   Reply With Quote
Old 10-04-2004, 09:31 PM   #1038
beetlebz's Avatar
Send a message via AIM to beetlebz
evan, i dont mean to assume youre a noob, if im patronizing you just tell me and ill feel bad
but are you letting the engine warm up? my truck will stall when i accelerate (sp?) if its still cold. i let it idle for a minute or two before i can nail the gas wide open, give it a chance to get hot.
if its hot and still doing it, then yeah it sounds like your LSN is too rich or lean.
beetlebz is offline   Reply With Quote
Old 10-04-2004, 10:55 PM   #1039
Aaron Waldron's Avatar
You need the fuel tubing running from the pipe to the carburetor. Tuning without this pressure line can cause headaches and will make your truck stall if you crash upside down.
Make sure you have no air leaks in the carburetor (it's best to seal it with a little bit of RTV) and that the tank and fuel line are in good shape.
mafia - It was a great experience..that's for sure. I will be racing with the big boys at every electric race from now on, but basically everyone who's anybody (with a few exceptions..bummer ) was there and it was MAD fun.
I did have about one bobble a race..and that was my biggest problem. The track was one of the toughest I've raced on and it was uncommon to see anyone drive the entire five minutes with no mistakes.
If you could have seen how fast we were going..man it was amazing.
nt - no problem!
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 10-04-2004, 11:11 PM   #1040
beetlebz's Avatar
Post
i was going to go this past saturday for my first ever race but it got rained out
oh well, theres always next saturday.
aaron, if you beat those guys, then they wouldnt be some of the best in the world anymore. so kickin the crap out of the majority of them is well worth the time id think congrats
btw, whats RTV?
Old 10-04-2004, 11:19 PM   #1041
RTV is a type of silicone sealant, you can find it at hardware and car parts stores.
I race against the world's best..and my goal is to beat as many of them as I can. I want to be known as one of the "world's best"....I'm workin' on it!
www.liverc.com
Old 10-05-2004, 02:13 PM   #1042
Evan's Avatar
ill try the warming up but every time it stalls i look at it a few seconds later (the time it takes me to run to it) and no fuel is in the lines. yeah sometimes you would never know my dad is the best car mechanic in my town!
Old 10-05-2004, 03:33 PM   #1043
Sofast-NT's Avatar
Aaron does anyone make a synthesized receiver for a JR XR3I?
Sofast-NT is offline   Reply With Quote
Old 10-05-2004, 03:39 PM   #1044
Casper's Avatar
Trader Rating: 33 (100%+)
JR does- the RS300 and the RS310 will both work with this radio. You will still have to use crystals for the radio though. The module is integrated with that redio from what I remember. The JR synthesized recievers will work prefect for that radio. I use the JR synthesized recievers in my gas truck with a MARS radio and it works flawless. This way I do not need to use crystals in my reciever and I cut a hole in the side of the battery box to quickly change the freq in my gas truck. It is AWSOME!
Casper is offline   Reply With Quote
Old 10-05-2004, 03:54 PM   #1045
Sofast-NT's Avatar
Thanks casper.I might get that receiver or i might save up my $ for a M-8.
Old 10-05-2004, 04:13 PM   #1046
Casper's Avatar
Get the RS310. It is a bit smaller then the RS300. The JR radio is AWSOME. I am not sure what more you want out of it. If you are going to get an M8 wait for the synthesized version to come out. It will be worth the wait to not have to use chrystals anymore.
Old 10-05-2004, 04:30 PM   #1047
stu541's Avatar
Trader Rating: 15 (100%+)
Default os 18
Evan, everyone's advice is correct. I would replace all the fuel line in case of an air leak then set the needles back to factory adjustment. O.s engines are bullet proof and the stock settings should get it started and running every time. if problem still occurs check engine for air leaks like aaron suggested. install a new plug when you change the line. basically I would start back at the beginning.
Hobby Pro USA, Maclan, Casterracingparts , RADIOPOST, Vp-Pro USA
stu541 is offline   Reply With Quote
Old 10-05-2004, 04:43 PM   #1048
Tyler Keel's Avatar
Hey Aaron, whats up?
How did the RTR go at HotRod? Where did you finish up?
Sux that I couldn't make it...flight was waaay to much But its all good, I hit up the Tumbleweed Classic instead..didn't go to bad...won 2wd stock
L8, TK
Tyler Keel - AE Region 9 Regional Director
Team Associated | Reedy | Jconcepts | Werks | Airtronics | Avid | Upgrade RC | Factory 1 RC
Tyler Keel is offline   Reply With Quote
Old 10-05-2004, 07:22 PM   #1049
Aaron,
You knew this question was coming....What was your setup in you MF-duce at the Reedy Race?
Thanks!
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 10-05-2004, 07:52 PM   #1050
mafia - The same setup I posted a couple of pages back..I like to keep things simple..haha.
It was my driving that needed work, not the truck!
Tyler - I got smoked. And I don't mean that in a bad way..the competition was very close, and very fast. The B-main was a great place to finish in that group of talented racers.
Casper - Thanks for the help
www.liverc.com
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
