Old 09-20-2004, 09:47 AM   #916
nutfluff's Avatar
Send a message via AIM to nutfluff
So Aaron. I was running my OS CV-R on a dusty track for about ten minutes...when I went to take the temp, I noticed the air filter had come off. Of course, I shut the engine down and called it a day.
What precautionary measures should I take before I run it again??
nutfluff is offline   Reply With Quote
Old 09-20-2004, 09:49 AM   #917
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Originally posted by Aaron Waldron
No no..when you're running on-road you are going to have smaller tires on. You need a larger clutch bell with smaller tires.
whoops.... thanks!
sorry... i am a little bit confused just now.. now is OK....
mop
mop_iko is offline   Reply With Quote
Old 09-20-2004, 09:52 AM   #918
mop_iko's Avatar
for me i would open up the WHOLE engine and give it a CLEANING session with NITRO CLEANER and a blast of air.... just to make sure no dirt is inside the engine.
make sure you got the engine diagram / manual with you before you open the guy up... unless you already know how to re-install it back together.
0.02
mop
Old 09-20-2004, 10:33 AM   #919
beetlebz's Avatar
Send a message via AIM to beetlebz
i would just take the head and backplate off, throw some nitro in there, let it drain out the back. then take off the carb and do the same up there. i wouldnt go any further than that if you didnt notice any ill effects.
beetlebz is offline   Reply With Quote
Old 09-20-2004, 11:30 AM   #920
Aaron Waldron's Avatar
nutfluff - 8 screws is all it takes to take the whole engine apart..give it a thorough flushing with fuel and WD-40 and it should be fine.
mop_iko - Let me know if you have any further questions.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 09-20-2004, 08:41 PM   #921
im pretty sure it is but ill redo it tell me how i can tell for sure. its like with the peace of paper right. and when you cant take it out its good or soemthing
vengeanceballa is offline   Reply With Quote
Old 09-20-2004, 10:26 PM   #922
beetlebz's Avatar
you could do it the old fashioned way. go outside and do hole shots for 10 minutes. if you strip your spur gear its too loose
seriously though, loosen the motor mounts (or however its adjusted on your car) and push it in all the way to the tightest possible gear mesh. then just spin the rear wheels by hand until it works quietly and has just a tiny bit of play.
i dont know the paper test
Old 09-20-2004, 10:38 PM   #923
Take a piece of paper and put it in between the spur gear and pinion gear, then slide the two gears together and tighten the motor mounts. If the gear mesh is correct, you'll be able to pull the paper out.
www.liverc.com
Old 09-21-2004, 12:39 AM   #924
beetlebz's Avatar
thats the same for nitro trucks too aaron?
Old 09-21-2004, 09:42 AM   #925
Yup, it's the same for anything. With 32 pitch gears (like what comes on a gas truck) you might have to fold the piece of paper in half, but it will work the same way.
www.liverc.com
Old 09-21-2004, 10:26 AM   #926
LBRODOG's Avatar
Send a message via AIM to LBRODOG
Aaron any word on those brush hoods?
LBRODOG is offline   Reply With Quote
Old 09-21-2004, 12:20 PM   #927
bigl's Avatar
Trader Rating: 31 (100%+)
LBORDOG check http://www.team-paradigm.com/ i think they carry what your looking for just click E-store then go to misc parts & accys
bigl is offline   Reply With Quote
Old 09-21-2004, 03:49 PM   #928
LBRODOG's Avatar
Bigl- Thanks for the help but all they have there is the P94 brush hood I am looking for the smaller brush hoods that went on to the D4 and earlier...
Old 09-21-2004, 05:27 PM   #929
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Aaron,
you've got a pm.
Thanks!
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 09-21-2004, 10:17 PM   #930
Adam - I haven't talked to anyone at Trinity for a while. Chad is online and I will leave him a personal message.
mafia - I'll hit you back.
www.liverc.com
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
