Old 08-16-2004, 03:58 PM   #631
LosiFromHell986's Avatar
Send a message via AIM to LosiFromHell986
Originally posted by mafiaracers
Either that or you just stuffed it into a pipe!-LOL
Shh... Don't tell....
That's not entirely correct... I stuffed it into a wall running parallel to me Took me out of the race though...
LosiFromHell986 is offline   Reply With Quote
Old 08-16-2004, 07:16 PM   #632
Dustinkeys's Avatar
What kind of 1/8 scale do you run.
Dustinkeys is offline   Reply With Quote
Old 08-16-2004, 08:51 PM   #633
Aaron Waldron's Avatar
I (will) run the brand new Jammin X1-CR, which will be sold through OFNA. The car is really trick, and with The Drake's help..it should be pretty darn good :-).
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 08-17-2004, 08:15 AM   #634
Send a message via AIM to DerekL
Hey... when is a good time to use taper pins on front and rear? and what about using evil twins,..... when are evil twins better than tapers? This is for a truck, of course
DerekL is offline   Reply With Quote
Old 08-17-2004, 11:42 AM   #635
I don't mean to sound biased, but I have never seen a surface where Evil Twins were better than Taper Pins, and I've been to my fair share of racetracks.
Taper Pins on the front of your truck will smooth out steering, especially entering the corner. I use 8-ribs on tracks with more than a few 180's that require lots of steering, and taper pins on basically any other blue groove track, specifically high speed tracks with long, sweeping corners.
www.liverc.com
Old 08-17-2004, 12:04 PM   #636
Ok, cool. Thank you. I just got a ton of new tires and have not really experimented with anything, soi i thought i should ask someone who knows what they are doing.
By the way, congrats on your last big win....
Old 08-17-2004, 02:09 PM   #637
Trader Rating: 59 (100%+)
Send a message via AIM to nitro kid
Post
do you have a web site i can look at what will tell me if i need a swag bar kit like if my car is doing this i need one
nitro kid is offline   Reply With Quote
Old 08-17-2004, 02:14 PM   #638
If you're racing modified on a very sticky blue groove track and you're traction rolling, then you might need a sway bar.
DerekL - Thanks
www.liverc.com
Old 08-17-2004, 02:25 PM   #639
Hey Aaron, do you know if I should use a Sway bar or not on a XXX4 at Family hobbies? (Rough, Loamy, tight...) We use IFMAR Studs all around.
Old 08-17-2004, 02:29 PM   #640
I wouldn't even try it.
www.liverc.com
Old 08-17-2004, 02:39 PM   #641
Casper's Avatar
Trader Rating: 33 (100%+)
I thought you used a swaybar all the time on the XXX4! I would not run one on a 2wd car though.
Casper is offline   Reply With Quote
Old 08-17-2004, 05:30 PM   #642
Casper - The track he's running at his loamy step pin dirt that gets bumpy. To me, I'd think that a swaybar would hurt in that situation.
Can't hurt to try it.
www.liverc.com
Old 08-17-2004, 07:28 PM   #643
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Oh yeah it would. The swaybar was the first thing to get pitched when I had a 4wd on that track. The stock setup isn't anywhere close to what worked out there. I'd have to look at my notes to see what I actually ended up running when it was fast.
Jon Kerr is offline   Reply With Quote
Old 08-17-2004, 07:29 PM   #644
Okay, thanks Aaron and Jon
Hopefully sometime soon I'll go out there and give it a run for it's money...
Old 08-18-2004, 03:55 AM   #645
Default Digital servos
Aw
Whats you opion on Digital servos verse anolog
THanks
Dmac
D Mac is offline   Reply With Quote
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
