Old 07-22-2004, 09:40 AM   #541
Send a message via AIM to JeffS
Default Re: Lungsford carb adabter
Originally posted by D Mac
AW
is their any way you know of to remove one of these adapters once installed.
Dave M
If you've JB welded it, probably not.
If you haven't, you could try heating it up with a lighter or some other moderate heat source and then wiggling it off, but the heat might damage the rubber in the carb, along with potentially squashing the carb barrel when you try to clamp on to the adapter when you remove it.
JeffS is offline   Reply With Quote
Old 07-22-2004, 12:06 PM   #542
Aaron Waldron's Avatar
elvo - Were you at Hemet? That's exactly what we were doing..haha.
Using the firmer foam will allow the ribs to dig into the dirt instead of simply folding over, due to the extra support the carcass is recieving from the foam. The only time I have run this is on a very loamy but well groomed track.
Ryan and I were doing this to get more steering..that's really the only reason.
Dave - Jeff hit the nail on the head.
NVisible - It is possible that a washer or something else is missing from the diff. If not, I know shims exist with the correct ID to shim the diff between the bearings..but I have no clue where I've gotten them from..
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 07-22-2004, 01:33 PM   #543
NVisible's Avatar
got it worked out Aaron. Thanks for your help!
NVisible is offline   Reply With Quote
Old 07-22-2004, 02:43 PM   #544
nutfluff's Avatar
Send a message via AIM to nutfluff
So Aaron--
You've recommended the .12 WASP but also like the OS .12 CV-R. Do you know how these engines compare??
PS Didn't look like such a big turnout this time at Babcock....Maybe he started too soon.
nutfluff is offline   Reply With Quote
Old 07-22-2004, 02:50 PM   #545
Send a message via ICQ to elvo
Aaron - no I wasn't.
It puzzles me why you use a red compound tire on a very loamy track.... but if it works- whatever!
Could you post your entire set-up for Hemet?
elvo is offline   Reply With Quote
Old 07-22-2004, 05:08 PM   #546
NVisible - Sorry I wasn't much help with that one!
nutfluff - Hemet is a long way away from a lot of the racers in LA and around Hot Rod..and being the weekend following the Shootout, many racers needed a break.
The WASP has more power and great mid-range grunt, but you'll need an O.S. carb (and adapter) to make the engine easy to tune and drive. The CV-R is a great engine in its own right, and costs less than the Wasp after you buy the O.S. carb and adapter.
elvo - Red compound tires will not catch on ruts as much as Silvers will, and are often more consistent on loamy surfaces.
I will post my setup when my dad gets home..he has the setup sheet with him.
www.liverc.com
Old 07-22-2004, 08:17 PM   #547
Yup goin back to Losi- for the simple fact that if you know you gotta win or if you gotta take one for the Team...its gotta be Losi!
I associate the gt with something I flush down the toilet.
Losi needs to come out with and 1/8th scale and they'll take over the world.
notch is offline   Reply With Quote
Old 07-22-2004, 09:55 PM   #548
skengines's Avatar
Trader Rating: 226 (100%+)
Hi
Do you have a link to Mike Weeds Paint, or A Main?
Thank You.
skengines is offline   Reply With Quote
Old 07-23-2004, 12:15 AM   #549
notch - Haha! I knew you'd see the light again someday..
skengines - I know Mike doesn't have a website..and your guess is as good as mine when it comes to A-Main Bodies. Sorry dude..
www.liverc.com
Old 07-23-2004, 01:24 PM   #550
Fran's Avatar
Trader Rating: 150 (100%+)
I bought a D6 motor 12x2 and it was absolute crap, we cut the com, put new brushes in, re-aligned the hood, broke it in and it still had horrible torque and no top end, we tried gearing it up, down, sideways. Still nothing, is it possible that we just got a bad motor? We're (me and my dad) are completely clueless.
Fran is online now   Reply With Quote
Old 07-23-2004, 02:05 PM   #551
jsp
Fran: What car, gearing, timing and brushes are you using? I assume you are running the Flat Wire?
john
jsp is offline   Reply With Quote
Old 07-23-2004, 05:51 PM   #552
Fran (I'm assuming it was Dan who typed that) - I'll take a look at the motor the next time I see you..probably the next JBRL race.
EVERYONE - I'm leaving for the third round of the Southern California Saturday Series at Pro-Line's facility in Banning, CA. Wish me luck!
www.liverc.com
Old 07-24-2004, 12:43 AM   #553
Fran's Avatar
Good Luck Aaron. It was indeed the flatwire, I believe 14 degrees of timing (although we went up to 20 trying to tweak it) I think stock spur gear with a 17 pinion or 18 tooth pinion in a XXX-4. We run our Maxtech 11x2 with a 17 tooth and it had punch and very good high end speed. I'll definatly show it to you at Camarillo Aaron. See if we can work on it a bit more.
Old 07-24-2004, 05:03 PM   #554
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Aaron,
I'm back! Finally! Anywhoo.....I'm running my XXX BK1 at a "big race" here in the next few days and had a question about your BK1 setup. You run the front link at 1-B. What exactly does that do for you? I'm going out to the track for some testing tomorrow so I'll try it and see how it feels. Otherwise here's what I'm planning on running.
Front:
30 -wt
57 -piston
silver -spring
.200" -limiter
2 on tower.....inside on arm
3-B link. However if the 1-B feels good then, I'll experiment more with that.
Rear:
27.5 -wt
56 -piston
yellow -spring....unthread 3 turns
no limiter
2 on tower......inside on arm
2-A link.
hub in middle
This track is VERY large http://www.amainraceway.com/content/...d_OD_track.asp So any thoughts and or comments are always apprecieated!
Thanks!
mafiaracers is offline   Reply With Quote
Old 07-25-2004, 08:03 AM   #555
Trader Rating: 59 (100%+)
Send a message via AIM to nitro kid
Post help help!!!!!!!!!!!!
our off-road track is down for repair so i'am going to put my 2wd buggy on a oval will 81/23 be better them 88/24 i'am looking for good off the line speed and over all speed
nitro kid is offline   Reply With Quote
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
