Old 06-24-2004, 01:22 PM   #451
I've check the price on Nitrohouse.
the PCR Pro kit is selling for $519.
Mugen MBX-5 is only $10 more at $529.
wouldn't it make more sense to get the Mugen, heard a better review and such with the mugen.
Jasonchi is offline   Reply With Quote
Old 06-24-2004, 03:35 PM   #452
Aaron Waldron's Avatar
I'm heading up to Hemet a day early for the RC Pro West Round 1 to practice with Adam.
I'll be back Sunday night. Wish me luck!
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 06-25-2004, 07:14 PM   #453
The Monster Horsepower, P2K2, and Epic Roar Stock motor all have "Epic" stamped on the endbells and armatures. Two motors are Trinity and one is just Epic. Are two of these motors the same thing or are they three different motors? What's the difference between Trinity and Epic?
Have you come up with a good baseline setup for your MF2 yet? I've only run the stock setup so far and I know it needs some work for my particular track. There seems to be too much steering and not enough rear traction and I'm using the appropriate tires for my track. Any suggestions would be appreciated.
Thanks, Tim
Timmerica is offline   Reply With Quote
Old 06-25-2004, 07:17 PM   #454
Techart27's Avatar
Hey Aaron,
Gotta question- I know this should be asked in the engine thread but since the MT-12 came with my MST-1 I'll ask it here first because of you expertises.
On a scale of 1-10 lets say 1 is idle and 10 is full throttle
From 1-3: Engine is strong, exhibits plenty of torque even though I am running the LSN on the rich side and has a healthy exhaust note
From 4-6: Here is the problem: During this band the engine seems like it is running out of RPM and very little speed is increase within this band. Also the sound from the engine sounds unhealty
From 7-10 : Suddenly the exhaust note changes DRAMATICALY. here the engine sounds very good and a big burst of power thrusts the car to its max speed and rpm soars freely and quickly. Once again i set my HSN on the rich side.
Is this normal? I read that slide carbs focus more on low and high end power while rotary carbs puts the power in the middle power band, but i ran with plenty of other .12's and they are MUCH smoother. I wonder if i could make my engine run smoother and have a better transitions from low end torque to high rpm power. Any help would be helpful. Thanks in advance.
Techart27 is offline   Reply With Quote
Old 06-26-2004, 12:26 AM   #455
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Aaron,
youve got a PM.
mafiaracers is offline   Reply With Quote
Old 06-28-2004, 03:47 AM   #456
mafia - Got it!
Tim - Trinity owns EPIC. For years (until very recently) EPIC was used as the name of the company used to make the the armature blanks, cans, and endbells for motors that Trinity sold, as well as many other companies such as Fantom and Peak (before being bought by Orion and the invention of the TOP motors).
The EPIC ROAR Stock motor is a re-labeled Monster. The P2K2 uses a different armature blank to focus the power lower in the RPM range.
The stock setup for the MF2 is a good place to start for bumpy and loose tracks. I like this setup myself:
Front: 57, 35wt, buggy blue springs, .200 limiting, inside on tower and arm, 3-b with 2 washers, .050 on spindle, spindle down.
Rear: 55, 35wt, yellow, no limiters, outside on tower and arm, 1-a camber link, hubs in middle
techart - The only way to make a noticable change in the power curve of a two-stroke motor (without some serious engine work) is to change the exhaust system. I see you're using the NovaRossi Rex pipe..and that is more than likely the cause of the symptoms you're describing. Try the Associated pipe (more low end) or the Team Losi Adam Drake Edition pipe (more midrange) for more manageable and usable power.
www.liverc.com
Old 06-28-2004, 06:35 PM   #457
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Yo Aaron! How did the RC Pro Series event go!? Nice and hot out there in the desert, I am sure!? I would have come out to scope the action, but I think it is almost 2 hours away from LA? I did run a little at So Cal on Saturday...
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 06-29-2004, 04:46 AM   #458
dragster's Avatar
Hi there Aaron,
What options are there in oneway f/diffs for XXX4, any info would be great
dragster is offline   Reply With Quote
Old 06-29-2004, 02:27 PM   #459
J - Man, you're killing me! You gotta start running more rut-rut bud. Are you going to the Hot Rod Shootout? I think I'm gonna try to run up there a little this weekend, and then I'll be up there from Tuesday night on for the race.
Adam nailed the holeshot and led the whole 45 minute main. I had some problems getting out of the starting gate cleanly, and had a hinge pin come loose about 7 minutes into the main..but I ended up 4th. The next RC Pro race is around the end of August up at Sun Valley, you should try to make that one!
dragster - Other than the stock diff, Losi offers a spool (which acts like a one-way, but offers front brakes) and a full one-way.
www.liverc.com
Old 06-29-2004, 02:38 PM   #460
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Take two tylenols. You'll be fine.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 06-29-2004, 03:10 PM   #461
I've had six already today bud. Ready for two more.
www.liverc.com
Old 06-29-2004, 03:11 PM   #462
RCTech Member #2
TSR6's Avatar
Dude, H2O is your friend.
Troy
RCTech Member #2
Old 06-29-2004, 03:45 PM   #463
After two gallons, does it lose its healing powers?
www.liverc.com
Old 06-29-2004, 04:13 PM   #464
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Filipow- Drop me an email. I'll send you some pics of the new crib (well, it's black right now with a roof and shingles, lol).
Dave Mac- PM me your phone number. Is Kannapolis running this Friday night? I need somewhere to break down the truck so I can take it to Pace's arse somewhere. If I have any missing pieces, I can give you a shout to see if you have them. Later.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 06-30-2004, 01:06 PM   #465
Trader Rating: 59 (100%+)
Send a message via AIM to nitro kid
Post help
Hi i have a bx buggy it came with a 81/23 is that good for a 19t motor and will it kill my batt fast are can i get like 9min out of it are what gear & pinion should i use
nitro kid is offline   Reply With Quote
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
