Old 08-16-2007, 03:05 PM   #3946
Aaron Waldron's Avatar
I've actually gone to using molded 56's with 25 wt. in the rear, as I think it makes the car more stable, especially through bumps and landing off of jumps. But that setup does work very well and it's worth a shot.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 08-17-2007, 09:01 AM   #3947
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
Originally Posted by yenrec View Post
Aaron.. ive had this brand new motor for about 3 years now and i never knew what it was... i just found out yesterday it was a mugen mt-12 novarossi and i need an exhaust and header, and air filter for it.... where can i find the right one to get? and what ones should i get? im going to put it in an older buggy or truck and just use it to mess around.. what do you suggest?
he ended up trading this engine to me.. well if you look here.. you will see this engine is far from brand new.. unless novarossi has some new service where they will fry your new engine for you.
mugen mt-12 novarossi for sale
looper is offline   Reply With Quote
Old 08-17-2007, 10:44 AM   #3948
trebor's Avatar
Thanks alot.
Feedback
[url]http://rctech.net/forum/showthread.php?t=153173&highlight=trebor[/url]
trebor is offline   Reply With Quote
Old 08-17-2007, 11:07 AM   #3949
looper - Ok.
trebor - No problem.
www.liverc.com
Old 08-17-2007, 01:03 PM   #3950
PRScustom's Avatar
Aaron, I have a quick question about my new 8ight T. When I got it it was built extremely well and the transmission spun freely. I got some hop-up parts for and put them on today. The one that gave me trouble was the rear aluminum bearing inserts. They were easy to install but once I had the truck all back together the transmission in the rear seemed to catch a little bit every 3 or 4 turn of the tires. I took the whole rear end apart twice and finally figured it out. Everything spins smoothly until I tighten the rear brace screws that hold in the hinge pins and pinch the diff housing together. The tighter I go the more resistance I feel in in the rear spinning when I push the car. If I leave them loose without snugging them no resistance is felt. If I barely snug them then just a little resistence is felt (barely noticeably but not as smooth as when I got the truck). If I crank them down then it is more noticeable. Right now I just barely have them snugged. What should I do? It doesn't seem to be any thing bad, like I said you can barely feel it, but it is not as smooth as when I got it. Should I just run the car (it has not been run yet because my engine has not arrived) and run it in, or is there something else I should do? I'm assuming the screws must be snug, they can't just be loose with the heads protruding out. Any help is welcomed. Thanks.
PRScustom is offline   Reply With Quote
Old 08-17-2007, 04:40 PM   #3951
It is normal that they will feel like they bind up a little bit when brand new.
Go ahead and crank the screws down, and run the truck a little bit. They will free up when they break in.
www.liverc.com
Old 08-17-2007, 07:39 PM   #3952
AzBobby's Avatar
ok Aaron i found the set up info i wanted. however after reading it i now have a ? about motor size. what is legal for truggy?
GO TECH
AzBobby is offline   Reply With Quote
Old 08-17-2007, 09:41 PM   #3953
redsand's Avatar
Send a message via Yahoo to redsand
Default Inserts
Hi Aaron: What do you think of the molded and foam inserts ? Which one is more preferable on a tight somewhat high traction track ?
redsand is offline   Reply With Quote
Old 08-18-2007, 01:53 AM   #3954
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I thought you were coming out tonight?
Jon Kerr is offline   Reply With Quote
Old 08-18-2007, 02:04 AM   #3955
Jon - Yeah, sorry I missed it. I ended up hanging out with the family tonight.
redsand - I haven't really messed around much with tuning 1/8th scale by using different foam inserts. Molded foam is a great concept, and will be awesome when the companies can get around the durability and consistency problems. It's too heavy for truggy, but it's not bad in buggy.
As a rule, more traction calls for a stiffer insert. If you're running on a track with good grip, try a harder foam like Trinity's gray bomb one foam.
Bobby - .28 is the max displacement for the 1/8th scale truck/truggy class. Many racers run .21's, because the extra power is not always necessary, and you'll get better mileage with a .21.
www.liverc.com
Old 08-18-2007, 02:17 AM   #3956
Jon Kerr's Avatar
Wow and you're still up at 2:00? That's cool. I'm kind of looking forward to having Saturday and Sunday with no plans at all.
Old 08-18-2007, 12:54 PM   #3957
Haha. I took my little brother and a couple of his buddies to see a movie last night, we didn't get back until late.
www.liverc.com
Old 08-18-2007, 05:57 PM   #3958
AzBobby's Avatar
thanks Aaron. well at least i race at the Pit mostly, so i dont really need all that much power.
GO TECH
Old 08-18-2007, 11:51 PM   #3959
Haha. Even so, most racers go faster with less power.
www.liverc.com
Old 08-20-2007, 10:48 AM   #3960
Default Truck nats
All I can say is Losi sure had some bad luck yesterday, But on a good note Losi won the Ohio pro series finals in buggy and truggy. Top 4 in buggy were all losi, Eric clark,Curtis May,The Curt, and me(Shane Racer). In truggy I was the only losi on the podium but I took the win. My truggy was dialed in the 40 min main and never looked back the hole race.
sracer is offline   Reply With Quote
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
