Old 06-13-2004, 08:13 AM   #376
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
I'm merely a messenger. Besides, I was tired of studying for my finals so I had nothing better to do....Three more days! Aaron, now that you're officially out of school (I think) are you taking a year off of jobs and college searches to hit every race this side of the equator? Or are you going straight to school? What college are you thinking about going to?
Peace!
mafiaracers is offline   Reply With Quote
Old 06-13-2004, 11:32 AM   #377
Aaron, thanks for your help again.
I'm looking forward to getting the MF2 tomorrow and the LST soon.
Have you been using the MF2? What are your impressions of the stock setup and do you recommend any adjustments to it?
Have you had a chance to use the LST? When do you hear it should be hitting hobby shops?
Which pre-programmed throttle profile do you recommend for stock racing with the GT7 esc? I've heard profiles 3 or 6 might be ok.
Thanks, Tim
Timmerica is offline   Reply With Quote
Old 06-13-2004, 11:41 AM   #378
Default Synthisized
Aron what do you think of the synthisized receivors with like thirty channels, Novac makes one, I have herd they have glitching problems especially for gas truck, what do you recommend.
Dave mac
D Mac is offline   Reply With Quote
Old 06-13-2004, 01:11 PM   #379
Aaron Waldron's Avatar
mafia - I finished finals on Thursday..graduation is Tuesday
I will be taking a full load at the local community college to get my general education classes taken care of, and still try to attend as many events next year as possible.
d mac - I run Novak's Switch module and XXTra receivers in my electric cars, and they're great. It's such a convenience to be able to dial in your frequency and go, instead of hassling with crystals. For gas truck, you need to make sure he reciever box is sealed from dirt and fuel very well, and to mount the reciever correctly (not on the chassis). I have plenty of friends that use them in their gas trucks and 1/8th scale buggies with no problems at all.
All radio systems will be synthesized soon; Airtronics is getting ready to release their own as well.
timmerica - My MF2 is still sitting in a bag..I haven't started building it yet. When the team gets home from the Nationals on Monday, I will post a good starting setup.
The LST is dialed..it's a total blast to drive. It should be here before the end of June I believe.
Profile 6 has the most punch. Profile 5 is a little softer initially but has more mid-high range power.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 06-13-2004, 01:56 PM   #380
Thankyou Aaron,
dmac
Old 06-13-2004, 02:42 PM   #381
No problem dude.
www.liverc.com
Old 06-13-2004, 03:17 PM   #382
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Aaron,
What color zip ties do you use to hold your tuned pipe & header together, air filter on, school lockers shut?
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 06-13-2004, 03:37 PM   #383
HAHAHA!!
Black for my R/C cars. White for school lockers and table pyramids.
www.liverc.com
Old 06-13-2004, 04:17 PM   #384
Hey aaron how are those king pin tires for tracks like revelation and the dirt...they look pretty dialed i was just looking for a new tire option other then my step pins to run.
blitz jon is offline   Reply With Quote
Old 06-13-2004, 04:19 PM   #385
RCTech Member #2
TSR6's Avatar
Originally posted by Aaron Waldron
HAHAHA!!
Thanks, I just wanted to check so I could make my lockers as fast as your lockers.
Troy
RCTech Member #2
Old 06-13-2004, 04:32 PM   #386
Troy - 2500 lockers in one hour..that's pretty fast!
Jon - Revelation and The Dirt are usually too loamy for those tires. There are times when Studs or IFMAR Pins work best at The Dirt, but I've never been to Revelation where it wasn't really loamy.
King Pins are aimed at tracks where you would use a Pro-Line Holeshot. Hot Rod Hobbies is a great example.
www.liverc.com
Old 06-13-2004, 11:30 PM   #387
WATTSON's Avatar
i just picked up a mf2 looks alsome
how do you get the new diff to feel right when it feels right it slips but when dont slip it feels like it needs a rebuild bad
WATTSON is offline   Reply With Quote
Old 06-13-2004, 11:34 PM   #388
Default GT7 Setup
I have a question reguarding the GT7 setup. I have an M8 and I'm familiar with the settings for A-D. Not sure what the 'middle setting' on E is exactly meaning. I'm also not familiar with F and G. Do these apply to the M8 and if so what settings are these? Thanks.
For proper ESC operation, adjust transmitter as follows:
A. Set HIGH ATV or EPA to maximum setting.
[amount of throw at full throttle]
B. Set LOW ATV, EPA, or ATL to maximum setting.
[amount of throw at full brakes]
C. Set EXPONENTIAL to zero setting.
[throttle channel linearity]
D. Set THROTTLE CHANNEL REV. SWITCH to either position.
E. Set THROTTLE CHANNEL TRIM to middle setting.
[adjusts neutral position/increases or decreases coast brakes]
F. Set ELECTRONIC TRIGGER THROW ADJUSTMENT to
70% throttle and 30% brake throw (or 7:3).
[adjusts trigger throw electronic/digital pistol-grip transmitters]
G. Set MECHANICAL TRIGGER THROW ADJUSTMENT
to position with 2/3 throttle and 1/3 brake throw.
[adjusts trigger throw on mechanical/analog pistol-grip transmitters]
GMorrisette is offline   Reply With Quote
Old 06-14-2004, 03:22 PM   #389
The Evicerator
"E" = throttle trim... IE, the little meter with an L at one side and H at the other. It is located just beside the steering trim meter.... the adjuster is at about 9 o'clock in relation to the steering wheel... it is labeled "trim-th"
"F & G" -- you do not need to worry about these settings with your M8, it is already set for 70/30. This means that approximately 70% of the trigger throw is allocated to throttle and 30% is allocated to brakes.
Hope this helps clear things up a bit
-Steve Weiss
Steve@teamnovak.com
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-14-2004, 04:21 PM   #390
Thanks Steve!
WATTSON - Allow the parts plenty of time to seat together and break in before you run it on the track. Try using Associated Black Grease for the thrust bearing as well.
Hope that helps.
www.liverc.com
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
