Old 07-20-2007, 02:23 PM   #3856
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Well, from what Aaron tells me about the B-mods head, it's much lighter, it draws more heat off the crankcase and actually cools the engine, rather than just having a cool heat sink and a hot crank case, which allows you to lean it out a little more and save more fuel.
Plus, they're pretty cool looking.
Jon Kerr is offline   Reply With Quote
Old 07-20-2007, 10:56 PM   #3857
AZRCaddict's Avatar
Mine looks so trick I can't wait to run it tomorrow
Team EMB
AZRCaddict is offline   Reply With Quote
Old 07-23-2007, 06:55 AM   #3858
Aaron.. ive had this brand new motor for about 3 years now and i never knew what it was... i just found out yesterday it was a mugen mt-12 novarossi and i need an exhaust and header, and air filter for it.... where can i find the right one to get? and what ones should i get? im going to put it in an older buggy or truck and just use it to mess around.. what do you suggest?
yenrec is offline   Reply With Quote
Old 07-23-2007, 02:27 PM   #3859
Trader Rating: 27 (100%+)
Boy you are lucky! That is an awesome engine, powerful/tuneable/very long lasting. Just get a losi .12 rear exhaust header and an ad2 pipe and you'll have an excellent combination. A losi gas truck air filter would work for ya too. Your local hobby shop should be able to hook you up, or try stormer hobbies, or horizon hobbies on the internet.
jbrow1 is offline   Reply With Quote
Old 07-23-2007, 06:17 PM   #3860
AzBobby's Avatar
so i thought i should tell that our friend Aaron here was caught cheating on us with an electric truck over the weekend at the shootout.
Good Job Aaron you had some really good runs.
GO TECH
AzBobby is offline   Reply With Quote
Old 07-26-2007, 01:12 PM   #3861
RBMike's Avatar
Aaron what is up with the back-order everywhere on the 8's rear outer hinge pins?
RBMike is offline   Reply With Quote
Old 07-26-2007, 01:59 PM   #3862
Jon Kerr's Avatar
Aaron running a flashlight truck and me running a Losi gas car. What's the world coming to?
Old 07-26-2007, 05:46 PM   #3863
r/c newbie's Avatar
hey Aaron,finally got mt r/c
got a traxxas nitro sport
any opinions on this model?
also,how long can I store it without using the storage procedure?
r/c newbie is offline   Reply With Quote
Old 07-30-2007, 11:07 AM   #3864
Aaron, finally bought an ad2 to compare with my gt2. Going to run Drake's dirt setup on it. Was surprised to see it runs pro squat on it. What is the reason for this and what conditions do you want to run pro squat? First setup I've ever seen with it.
Old 07-30-2007, 01:29 PM   #3865
Aaron Waldron's Avatar
air8 - Jon's referring to the O.S. Speed with the magnesium head. Magnesium is very light but the heat from the engine doesn't transfer well from the aluminum case to the mag head. The B-Mods heads are very light but still made of aluminum.
yenrec - Just like jbrow said, if you're looking to put the engine into a gas truck.
Bobby - Too funny! I had a blast racing flashlights, it was a cool change and I had a lot of fun battling with guys that race electric all the time. I didn't do too bad for someone who races 1/8th scale all the time.
Mike - I'm not sure why they're gone, but I know Losi is working on getting the hinge pins, and all of their parts, back in stock. It might take a while, but they're working on it.
Jon - Haha. But I grew up racing flashlights, it's not too much of a departure for me.
newbie - Traxxas makes great stuff, and the Sport will be a nice introduction to the hobby.
I wouldn't plan on storing your car for more than a day without after-run oil.
jbrow - The pivot block has 2 degrees of anti-squat built in; the washers used on the Drake setup take away 1 degree, which means the truck still has 1 degree of anti-squat, not pro-squat. Decreasing anti-squat should make the car smoother and add on-power steering.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 07-30-2007, 01:49 PM   #3866
Ahaha that makes more sense. Thanks.
Old 07-30-2007, 02:40 PM   #3867
r/c newbie's Avatar
Aaron, my nitro sport has a problem.I run it as usual,but for some reason it died and smoke came out of the exaust after it killed,how can i fix that and prevent that from happening againby the way it has a pro.15 traxxas engine
win or break somethin' tryin'
Old 07-30-2007, 02:41 PM   #3868
r/c newbie's Avatar
also the engine was extremelt hot.
Old 07-30-2007, 05:25 PM   #3869
AzBobby's Avatar
Aaron its cool you did a great job. it will only help you get faster in 1/8 as im sure you know.
Seen any cool snakes lately?
GO TECH
Old 07-30-2007, 06:14 PM   #3870
jbrow - No problem. :-)
Bobby - Electric is nothing new to me. It's fun and 2wd modified will make anyone a better driver.
Snakes are NOT COOL!
newbie - Will the engine restart? You may not have a problem at all. Hot oil in the pipe will produce smoke, even after you shut the engine off or it dies.
www.liverc.com
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
