Old 07-17-2007, 10:03 AM   #3841
So I am just wondering, what do you pros do to clean your car? I know the car doesn't really have to be clean if we make sure the dirts isn't links and joints, but sometimes it just gets too dirty and it makes you want to clean it. Especially, when the car is new.
Also most the ball bearings on my 8ight that are exposed to the outside are already contaminated with dirt at its 3rd gallon. It is very hard to turn the ball bearing because of the dirt that got into it. Is this suppose to be the normal lifetime of the ball bearings that came with the RTR kit? Or is there a way to clean the dirt? I tried soaking it with WD40 and shaking it in a container and it didnt work too well.
kmaheartless is offline   Reply With Quote
Old 07-17-2007, 11:29 AM   #3842
Aaron Waldron's Avatar
WD-40, an old toothbrush, and an air compressor. When you've got the car in pieces you can rinse things off in the sink, just make sure you get everything clean and dry before you put it back together.
Bearings need to be cleaned a little more regularly than every couple gallons. If you're running in sandy conditions especially, it's a good idea to take them out every once in a while and wash them out. Spray the dirt out with motor spray and re-lube them with bearing oil (or a drop of motor oil, Losi has always recommended Mobil 1). If you can't get the bearing smooth again, you should replace it.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 07-17-2007, 08:56 PM   #3843
AzBobby's Avatar
hey Aaron, im looking for the Losi heat shield tape, it used to come with two strips in it. for the inside of the body so you dont blow out a nice paint job. i cant seem to find a part number or anyone online who has it. Help.
AzBobby is offline   Reply With Quote
Old 07-17-2007, 09:58 PM   #3844
odoylrulz's Avatar
where do I mount a personal transponder on the losi 8ight? thanks in advance
odoylrulz is offline   Reply With Quote
Old 07-17-2007, 10:33 PM   #3845
AZRCaddict's Avatar
Google is great!
http://www.amainhobbies.com/index.php/cPath/1_25_175
UpGrade has some also...
http://www.amainhobbies.com/product_...oducts_id/7106
Team EMB
AZRCaddict is offline   Reply With Quote
Old 07-17-2007, 11:00 PM   #3846
Cody - Thanks for looking that up.
odoyrulz - Under the radio tray, just behind the receiver box.
www.liverc.com
Old 07-17-2007, 11:00 PM   #3847
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
It gets screwed in with 2 screws right behind the receiver box and switch location. I put mine under the radio tray, some put it on top, either works, but lower is better for picking up the signal.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 07-17-2007, 11:02 PM   #3848
-- Everyone --
I am leaving in the morning for the 10th annual Hot Rod Shootout, and I'll be home Sunday night. Leave me any questions you have and I'll get to them when I get back!
www.liverc.com
Old 07-18-2007, 12:02 AM   #3849
air8's Avatar
Drive smart. But we know you will. lol
air8 is offline   Reply With Quote
Old 07-18-2007, 07:17 AM   #3850
odoylrulz's Avatar
thanks for the help guys
Old 07-19-2007, 11:27 AM   #3851
Problems tuning an Axial .28 spec 1 at 5000' above sea level
I have been having problems with my Axial when the weather heats up. I have found that it dies and becomes hard to start as the weather gets hotter. I was running a hot plug and changed to a cold one but haven't got out to check it out yet. I live in Colorado and with our higher altitude I have even tried richening the high speed some but the engine is only running around 225.
HELP!
I really want to get this going again. Also, I am running a JP-3 pipe and have the engine in a Kyosho ST-USSport truggy.
RichSavage is offline   Reply With Quote
Old 07-19-2007, 11:56 AM   #3852
Kcdzim's Avatar
Send a message via AIM to Kcdzim
HELP!
At higher elevations, the air is thinner. Air also becomes thinner when hot. You should actually be LEANING out the engine, not richening, since you have less oxygen in the air and need less fuel for the proper mix.
Kcdzim is offline   Reply With Quote
Old 07-19-2007, 02:13 PM   #3853
Trader Rating: 27 (100%+)
Originally Posted by Aaron Waldron View Post
-- Everyone --
Happy racing and good luck to ya!!
jbrow1 is online now   Reply With Quote
Old 07-19-2007, 09:32 PM   #3854
Jon Kerr's Avatar
I had to lean out my Ninja motor 4 or 5 hours when we started running at our new track. And it's probably only 600-700 foot in elevation higher than where we normally run.
Aaron. I ordered one of the B-mods heads for my new OS motor. Can't wait to get it on the car.
Good luck at the Shootout.
Jon Kerr is offline   Reply With Quote
Old 07-20-2007, 11:43 AM   #3855
air8's Avatar
Jon--what makes you want to run a different cooling head? Durability, decrease temp, or something else?
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
